How to make the time series X axis only show months, not weeks?
    Mac OS Sequioa
Trying to get it so that only MONTHS are shown on the X axis, rather than weeks and then one data point per month
    Been trying to use the panel settings, Panel JSON and somehow do it with the SQL query but no dice thus far
  • What happened?
    X axis tick for every week
    Expected to have only X axis ticks where i had data points (one per month)
    Panel JSON:
    “id”: 7,
    “type”: “timeseries”,
    “title”: “% of pregame markets won”,
    “gridPos”: {
    “x”: 0,
    “y”: 16,
    “h”: 8,
    “w”: 12
    “fieldConfig”: {
    “defaults”: {
    “custom”: {
    “drawStyle”: “line”,
    “lineInterpolation”: “linear”,
    “barAlignment”: 0,
    “barWidthFactor”: 0.6,
    “lineWidth”: 1,
    “fillOpacity”: 0,
    “gradientMode”: “none”,
    “spanNulls”: false,
    “insertNulls”: false,
    “showPoints”: “auto”,
    “pointSize”: 5,
    “stacking”: {
    “mode”: “none”,
    “group”: “A”
    “axisPlacement”: “auto”,
    “axisLabel”: “”,
    “axisColorMode”: “text”,
    “axisBorderShow”: false,
    “scaleDistribution”: {
    “type”: “linear”
    “axisCenteredZero”: false,
    “hideFrom”: {
    “tooltip”: false,
    “viz”: false,
    “legend”: false
    “thresholdsStyle”: {
    “mode”: “off”
    “color”: {
    “mode”: “palette-classic”
    “mappings”: ,
    “thresholds”: {
    “mode”: “absolute”,
    “steps”: [
    “value”: null,
    “color”: “green”
    “value”: 80,
    “color”: “red”
    “overrides”: [
    “matcher”: {
    “id”: “byName”,
    “options”: “games_with_pregame_volume”
    “properties”: [
    “id”: “custom.hideFrom”,
    “value”: {
    “tooltip”: false,
    “viz”: true,
    “legend”: true
    “matcher”: {
    “id”: “byName”,
    “options”: “profitable_pregame_games”
    “properties”: [
    “value”: {
    “tooltip”: false,
    “viz”: true,
    “legend”: true
    “matcher”: {
    “id”: “byName”,
    “options”: “profitable_pregame_rate”
    “properties”: [
    “id”: “color”,
    “value”: {
    “mode”: “fixed”,
    “fixedColor”: “green”
    “pluginVersion”: “12.1.0-88106”,
    “targets”: [
    “refId”: “A”,
    “format”: “table”,
    “rawSql”: “SELECT\n DATE_TRUNC(‘month’, settled_day)::timestamp AS time,\n TO_CHAR(DATE_TRUNC(‘month’, settled_day), ‘YYYY-MM’) AS month_label,\n COUNT() FILTER (\n WHERE "pregame_volume [hidden]"::numeric > 0\n ) AS games_with_pregame_volume,\n COUNT() FILTER (\n WHERE "pregame_volume [hidden]"::numeric > 0 AND pregame_pnl > 0\n ) AS profitable_pregame_games,\n ROUND(\n 100.0 * COUNT() FILTER (\n WHERE "pregame_volume [hidden]"::numeric > 0 AND pregame_pnl > 0\n )::numeric / NULLIF(COUNT() FILTER (\n WHERE "pregame_volume [hidden]"::numeric > 0\n ), 0),\n 2\n ) AS profitable_pregame_rate\nFROM game_level_margin_daily\nWHERE $__timeFilter(settled_day)\nGROUP BY DATE_TRUNC(‘month’, settled_day)\nORDER BY time;\n”,
    “editorMode”: “code”,
    “sql”: {
    “columns”: [
    “type”: “function”,
    “parameters”:
    “groupBy”: [
    “type”: “groupBy”,
    “property”: {
    “type”: “string”
    “limit”: 50
    “dataset”: “postgres”,
    “rawQuery”: true
    “datasource”: {
    “uid”: “ceffjw790d24gc”,
    “type”: “grafana-postgresql-datasource”
    “options”: {
    “tooltip”: {
    “mode”: “single”,
    “sort”: “none”,
    “hideZeros”: false
    “legend”: {
    “showLegend”: true,
    “displayMode”: “list”,
    “placement”: “bottom”,
    “calcs”:
What is your data source? Can you group data by month there?
Hello @finneganlsmith for my suggestion you can disply month when you move your pointer at particular time range like this…
for this you can simply change the unit.
