I am trying to connect my existing RESTfull API with JSON data response to Grafana dashboard to create some graphs. How do I do this?
I have done some research and found SimpleJson addon, but this require changes in my back-end API. Is there any other way to do this other then SimpleJson addon.
I tried the same think with REST API on Cisco Prime Infrastrcuture but this is not the good way !
Obviously you do the same approach
There are so many change that you must to do on your back-end API ?
