How to use webapi datasource?
how to use webapi datasource?
Maybe you can try SimpleJson as a data source, so your api can communicate with Grafana through json. Check it out.
谢谢,但是SimpleJson需要后台服务实现4个接口,但是我的后台没实现那几个接口,所以不能直接使用。
