RestAPI to feed Grafana and visualize the data
Our department feeds Grafana with a RestAPI to do data visualization, and our API returns a Javascript form. We can change the returned data format to meet Grafana’s standard. Is it possible to deploy it on Grafana Cloud or locally? Where can I find your format? The pricing is 49 USD/month?Please advise, thank you.
If I understand your question right, you should be able to use the “Simple JSON datasource” to achieve this. The required endpoints/format, as well as how to install it, are described here: https://grafana.com/grafana/plugins/grafana-simple-json-datasource
I haven’t used Grafana Cloud myself, but believe this is available on Cloud also (and definitely if you have your own install)
