Hello grafana gurus! I’ve never used grafana before, but my company uses it all the time to visualize data and I have a use case that I think is perfect, but I just can’t seem to get my data formatted/transformed the way I need. I have a bunch of JSON exports from API calls I’ve done at a customer every hour for a couple days, so they’re just local JSON files on my machine now (which I think may be part of the problem). The JSON files are in this format:
"name": "foo_1",
"id": 3,
"stats": {
"aggregate_total_lines": 447464,
"current_total_lines": 412547,
"remaining_lines": 103054
"name": "foo_2",
"id": 83,
"stats": {
"aggregate_total_lines": 871750073,
"current_total_lines": 169822988,
"remaining_lines": 4632
There are ~400 foos in each one, and each one has the same foos but different numbers. I’d like to graph out each of those stats for each of the foos, so I can see the trend over time.
I’ve tried the Infinity plugin with a couple sample JSONs and although I can get the data in there as a table for each, I don’t know how to join the tables together based on each foo ID. I’m sure I’m missing something super obvious, but I just can’t seem to figure it out. Any advice would be greatly appreciated! Thanks!
