I am using grafana 9.2.3 in docker. I would like to upgrade business text plugin from version 2.0 to 4.5.0. What is the command to upgrade the plugin to a specific version?
It depends how you installed that plugin.
Thank you for your response,
Previously, I have installed that plugin using the below command and executed inside the docker container
grafana-cli plugins install marcusolsson-dynamictext-panel
I would use env variable GF_INSTALL_PLUGINS on the container level, you can define plugin version explicitly there, e.g.
GF_INSTALL_PLUGINS=grafana-dynatrace-datasource 0.9.5,grafana-splunk-datasource 3.0.1,grafana-servicenow-datasource 2.2.6
Of course also cli has support for plugin version.
grafana cli plugins install <plugin-id> <version>
