Recently i upgraded from Grafana 5.4.3 to 6.0.0.
Then i noticed that some plugins have updates available.
I’m running grafana in a docker container, and when i try to update all plugins with grafana-cli i get the following:
If i try, for instance update my clock panel plugin, i got the following:
And same with the vonage-status-panel:
The strange thing is that i do an ls of the plugins, they are there:
Is this a misconfiguration on the grafana.ini?
Thank you in advance
