Hello everyone, I have the following plugins:
[root@port ~]# grafana-cli plugins ls
installed plugins:
vonage-status-panel @ 2.0.0
grafana-simple-json-datasource @ 1.4.2
alexanderzobnin-zabbix-app @ 4.5.5
grafana-clock-panel @ 2.1.8
grafana-image-renderer @ 3.11.5
dashlist @
grafana-worldmap-panel @ 1.0.6
marcusolsson-treemap-panel @ 2.0.1
grafana-piechart-panel @ 1.6.2
[root@port ~]#
I updated them, then I restarted grafana, and I got an error:
In the logs I saw level=error msg=“plugin process exited” plugin=/var/lib/grafana/plugins/grafana-image-renderer/plugin_start_linux_amd64 id=18022 error=“exit status 1” after deleting the plugin grafana-image-renderer starts working as soon as I install it and reboot grafana, then it stops working again
