i was setting up a new install on a different PC. ver 11.1.3 does not allow me to show a graphic like I could in version 11.
also, version 11.1.3 has the error “Missing panel reference ID” on the clock plugin.
are you using sqlite as grafana backend?
i have not changed anything . if that’s how is installed then that’s how it’s installed.
how did you upgrade? what were the steps you took for upgrade?
going back to ver 11.
