Grafana v13.0.1
hello @dgr75 which os and grafana panel visualization you are using (ie.table ,stat)?
ok , please clear the browser history and cache, and restart the grafana service.
and check if still issue , increase the panel hight and save it and check , or
Unlink the library panel and then check ok or not.
thanks
After clearing the browser history and cache and restarting the Grafana service, nothing changed.
I added the first Library panel to this dashboard, and it was fine.
Afterward, when I accessed the same dashboard on my smartphone, no data was displayed again (only when I zoomed in). After saving it on my smartphone, the newly added Library panel also failed to display any data on my tablet or PC (again, only when I zoomed in).
The library panels were re-imported and everything was saved. After reloading the dashboard, everything was correct. However, this only affected the display on the PC. The smartphone showed the wrong status.
Grafana was closed and restarted. After reloading the dashboard, everything was gone again.
How can I restore the Grafana version prior to v13.0.1?
Can I replace the new version with “sudo apt-get install grafana=12. 3.1” ?
Yes, you can downgrade Grafana using apt, but not exactly like that command unless the version exists in your repo.
Check available versions
Install specific version
sudo apt-get install grafana=12.3.1
Prevent auto-upgrade
Restart Grafana
sudo systemctl daemon-reexec
sudo systemctl restart grafana-server
Yes,you can downgrade.
Unfortunately, there was an error during the installation.
pi@raspi2:~ $ grafana server -v
Version 13.0.1 (commit: a100054f21, branch: HEAD)
pi@raspi2:~ $ sudo systemctl stop grafana-server
pi@raspi2:~ $ sudo apt-get install grafana=12.3.1
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.47+rpt-common-rpi linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt
Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
Die folgenden NEUEN Pakete werden installiert:
grafana
0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 185 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 687 MB Plattenplatz zusätzlich benutzt.
Holen:1 https://apt.grafana.com stable/main arm64 grafana arm64 12.3.1 [185 MB]
Es wurden 185 MB in 23 s geholt (8.142 kB/s).
Vormals nicht ausgewähltes Paket grafana wird gewählt.
(Lese Datenbank ... 129272 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../grafana_12.3.1_arm64.deb ...
Entpacken von grafana (12.3.1) ...
dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/grafana_12.3.1_arm64.deb (--unpack):
Versuch, »/usr/lib/systemd/system/grafana-server.service« zu überschreiben, welches auch in Paket grafana-enterprise 13.0.1 ist
dpkg-deb: Fehler: »einfügen«-Unterprozess wurde durch Signal (Datenübergabe unterbrochen (broken pipe)) getötet
Fehler traten auf beim Bearbeiten von:
E: Sub-process /usr/bin/dpkg returned an error code (1)
pi@raspi2:~ $ sudo systemctl start grafana-server
Here’s the error again:
dpkg: error processing archive /var/cache/apt/archives/grafana_12.3.1_arm64.deb (–unpack):
Attempting to overwrite ‘/usr/lib/systemd/system/grafana-server.service’ which is also in package grafana-enterprise 13.0.1
dpkg-deb: error: ‘insert’ subprocess was killed by signal (broken pipe)
Errors were encountered while processing:
which version you want to downgrad grafana-enterprises or grafana oss??
I think it’s Grafana Enterprise. How can I verify that?
try this
sudo apt install --allow-downgrades grafana-enterprise=12.3.1
grafana-server -v
pi@raspi2:~ $ sudo apt install --allow-downgrades grafana-enterprise=12.3.1
Die folgenden Pakete werden durch eine ÄLTERE VERSION ERSETZT (Downgrade):
grafana-enterprise
0 aktualisiert, 0 neu installiert, 1 durch eine ältere Version ersetzt, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 196 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 331 MB Plattenplatz freigegeben.
Möchten Sie fortfahren? [J/n] j
Holen:1 https://apt.grafana.com stable/main arm64 grafana-enterprise arm64 12.3.1 [196 MB]
Es wurden 196 MB in 25 s geholt (7.847 kB/s).
dpkg: Warnung: Version 13.0.1 des Paketes grafana-enterprise wird durch ältere Version 12.3.1 ersetzt
Vorbereitung zum Entpacken von .../grafana-enterprise_12.3.1_arm64.deb ...
Entpacken von grafana-enterprise (12.3.1) über (13.0.1) ...
grafana-enterprise (12.3.1) wird eingerichtet ...
Restarting grafana-server service... OK
-bash: grafana: Kommando nicht gefunden.
pi@raspi2:~ $ grafana-server -v
Version 12.3.1 (commit: 0d1a5b4420a5e4579b91c239ecb240ea2b247fba, branch: HEAD, enterprise-commit: 2a9691bd01b56d649d9fd494d0166752f0891473)
pi@raspi2:~ $
Wonderful! Everything is back to normal.
Thank you for the fantastic help!
