v9.5.6 - What are you trying to achieve?
Update library panel using (/api/library-elements/) API - How are you trying to achieve it?
curl -s -XPATCH
-w ‘%{http_code}’
–dump-header headers.txt
-H “Authorization: Bearer $GRAFANA_API_TOKEN”
-H ‘Content-Type: application/json’
“$GRAFANA_URL/api/library-elements/$LIBRARY_PANEL_UID”
-o update_result.json
-d @updated_library_panel.json)
where (updated_library_panel.json) is the panel Json im trying to update - What happened?
when updating the panel, the query disappeared from the panel and it show me (none) on the panel result. the error i got is (D.query is not a function) - What did you expect to happen?
i expect to have the same source panel since i took the query from it - Can you copy/paste the configuration(s) that you are having problems with?
i generate (updated_library_panel.json) using the below code
import json
print("Building Library Panel json file ")
with open(‘current_library_panel.json’) as lib_json_file:
lib_panle_json_file = json.load(lib_json_file)
current_panel_version = lib_panle_json_file[‘result’][‘version’]
with open(‘payload.json’) as payload_json_file:
payload_file = json.load(payload_json_file)
for panels in payload_file[‘dashboard’][‘panels’]:
if ‘title’ in panels.keys() and panels[‘title’] == ‘XXXX’:
print(panels)
library_panel_json = {
“model”: panels,
“kind”: 1,
“version”: current_panel_version
with open(“updated_library_panel.json”, “w”) as output_file:
json.dump(library_panel_json, output_file)
Then i update the file panel using
curl -s -XPATCH
-w ‘%{http_code}’
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No - Did you follow any online instructions? If so, what is the URL?
No
Note im using grafana-lib to generate code, thats why i need the API to update the library panel
another note , that i noticed the some panels can be updated without any problem, and some other had a problem, which i cant know whats the issue(expect that im using transform heavily which it could be the porblem)
