11.1.3, linux
Edit library panels after creation -
“Edit” menu option which opens “edit panel” view -
What happened?
Query type is “random walk” instead of the variable type, in this case ${datasource}
also in the panel JSON the datasource is listed out as
"datasource": { "0": "$", "1": "{", "2": "d", "3": "a", "4": "t", "5": "a", "6": "s", "7": "o", "8": "u", "9": "r", "10": "c", "11": "e", "12": "}" },
instead of like the below
"type": "prometheus",
"uid": "zHDFgJmnk"
To be alble to edit -
I tried but it blocks me from creating te issue because I am a new user. I have included below a gist of these items
Grafana traces · GitHub -
i is undefined(uncaught type error from [module.ts:33:4] -
Edit panel no query
