Hello, everyone, I can no longer modify any requests in my panels.
I am using version 9.4.7
The only solution for this to work is to add a new query.
Someone with an idea?
THANK YOU!!
THANK YOU!!
Hi @sluchini
Can you please try to reproduce this same issue on https://play.grafana.org/ and then share the dashboard link so that we can view it?
OR
share some more screenshot or a small screencast/gif file which contain step-by-step instructions on how to reproduce it, so that we can do the same on our test machine.
Thanks
I don’t think I can reproduce the case on another grafana, I think the problem is only mine.
Here an video
Indeed I do not reproduce on your site
On my grafana even if I copy paste a panel I have the same problem.
Thanks for the screencast. Since you are using the JSON Infinity DataSource plugin.
Is the problem also visible in other Datasource plugins e.g. MySQL, TestDB etc? (can you check and verify)?
Since when you started to notice this problem e.g. after updating to a newer version (while in the previous version worked fine)?
