I am using Grafana version 8.1.1 in a docker with portainer -
I want to edit a saved dashbord -
Before I was able to click on the arrow, on the right onthe panel title and select Edit -
What happened?
Today, when I click on this arrow, the panel is blue and when I stop clicking the panel is redisplayed, -
I don’t have the scroll menu to select edit -
no errors -
I reply to myself
I have put in the ENV :
GF_AUTH_DISABLE_LOGIN_FORM to true
GF_USERS_ALLOW_SIGN_UP to false
I remove these two variables , restart grafana
and now it is working, I have the menu as before…
I can close this post
