Can't edit my panel any more
    Local installed on a Raspberry Pi with all update but can’t find the Grafana Version
    Try to edit a panel
    with the mouse on the top of the panel which to select but not working
  • What happened?
    the panel get blue, and can’t edit. also going with the Mouse over the panel and press e is not working
    should be able to edit the panel
strange - the next day it works like befor, i am confuse
@vikozo
still having this issue?
No, reboot the computer did not help. but a couple of hours later suddenly it works!
