I am an administrator and I lost the permission for editing each panel. (show options -disabled-). I uninstalled Grafana and reinstalled it again (Windows 10) but I still can not edit. How can I get the ability o editing back?
you have to log in as administrator. thank you
I log as administrator, but is not working
In the permission are ok, but I can’t edit. I can create a panel, write the query but when I try to edit the graph (the axes), the options button doesn’t work. And if I close the panel, I can not open the edition (the top arrow).
have you cleared browser caches?
Thanks, now I can edit new dashboards, but I still cannot edit inside my previous dashboards, How can I make them editable? I have saved them as json files.
I can not edit the panels after I created them ¿what is happening?
