Grafana v8.1.2 , Linux ubuntu 20.04 -
PlugIn development: Can I prebuild an influx query from the panel options with preset pull down menu items and have it populated to the data section raw queries? Is this possible? -
Not sure if this is possible with the framework. -
What happened?
Designing a new plugin for specific influx queries. -
Following the plugin development instructions from the docs.
First off, since panels are designed to not depend on any specific data source, this is not a well supported use case. I think accessing the data source from your panel options is going to be tricky, and updating the query model would be even trickier.
That being said, here are a few tips that might help you (though I could also be leading you on a wild goose chase):
- You can access a specific data source instance by using the
getBackendSrv()function to list all data sources. - Within the render method of a panel, you can get the id of the data source that was used for the specific query, but I’m not sure how you’d update the
jsonDatamodel with that approach. - If it’s a custom data source that you controlled, you could add a method on the data source instance, and then invoke it from the panel. For a built-in data source like InfluxDB, that’s likely not going to work though.
