Grafana not starting after update to 10.1.0
Grafana on Raspberry Pi 4
Log entry:
logger=settings t=2023-08-24T20:23:03.460142197+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
logger=settings t=2023-08-24T20:23:03.460196753+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
logger=settings t=2023-08-24T20:23:03.460251104+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
logger=settings t=2023-08-24T20:23:03.460307789+02:00 level=info msg=Target target=[all]
logger=settings t=2023-08-24T20:23:03.460399511+02:00 level=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2023-08-24T20:23:03.460454159+02:00 level=info msg=“Path Data” path=/var/lib/grafana
logger=settings t=2023-08-24T20:23:03.460507881+02:00 level=info msg=“Path Logs” path=/var/log/grafana
logger=settings t=2023-08-24T20:23:03.460560158+02:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2023-08-24T20:23:03.460613047+02:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
logger=settings t=2023-08-24T20:23:03.460672528+02:00 level=info msg=“App mode production”
logger=sqlstore t=2023-08-24T20:23:03.461709893+02:00 level=info msg=“Connecting to DB” dbtype=sqlite3
logger=sqlstore t=2023-08-24T20:23:03.461821022+02:00 level=warn msg=“SQLite database file has broader permissions than it should” path=/var/lib/grafana/grafana.db mode=-rwxrwxrwx expected=-rw-r-----
logger=migrator t=2023-08-24T20:23:03.602687085+02:00 level=info msg=“Starting DB migrations”
logger=migrator t=2023-08-24T20:23:03.642098359+02:00 level=info msg=“migrations completed” performed=0 skipped=493 duration=3.761482ms
logger=secrets t=2023-08-24T20:23:03.646786169+02:00 level=info msg=“Envelope encryption state” enabled=true currentprovider=secretKey.v1
logger=plugin.loader t=2023-08-24T20:23:03.822335806+02:00 level=warn msg=“Plugin missing module.js” pluginID=input warning=“Missing module.js, If you loaded this plugin from git, make sure to compile it.”
logger=plugin.loader t=2023-08-24T20:23:03.822987432+02:00 level=info msg=“Plugin registered” pluginID=input
logger=local.finder t=2023-08-24T20:23:03.823337116+02:00 level=warn msg=“Skipping finding plugins as directory does not exist” path=/var/lib/grafana/plugins
logger=query_data t=2023-08-24T20:23:03.834028176+02:00 level=info msg=“Query Service initialization”
logger=live.push_http t=2023-08-24T20:23:03.844831235+02:00 level=info msg=“Live Push Gateway initialization”
logger=ngalert t=2023-08-24T20:23:03.868697824+02:00 level=warn msg=“Unexpected number of rows updating alert configuration history” rows=0 org=1 hash=e0528a75784033ae7b15c40851d89484
what version did you update from?
10.0.3
Can you do tail -f log_file and revisit the Grafana page to see the exact logs it produces.
:laughing: you downgraded? 10.0.3 to 10.1.0?
I think thats an upgrade. 10.1.0 > 10.0.3 xD
logger=settings t=2023-08-24T21:01:29.94876407+02:00 level=info msg=“Starting Grafana” version=10.1.0 commit=838218ba20 branch=HEAD compiled=2023-08-23T12:52:21+02:00
logger=settings t=2023-08-24T21:01:29.949728841+02:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-08-24T21:01:29.949843174+02:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2023-08-24T21:01:29.949899488+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.data=/var/lib/grafana”
logger=settings t=2023-08-24T21:01:29.949963192+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
logger=settings t=2023-08-24T21:01:29.950016988+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
logger=settings t=2023-08-24T21:01:29.950074635+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
logger=settings t=2023-08-24T21:01:29.950137561+02:00 level=info msg=Target target=[all]
logger=settings t=2023-08-24T21:01:29.950233708+02:00 level=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2023-08-24T21:01:29.950288171+02:00 level=info msg=“Path Data” path=/var/lib/grafana
logger=settings t=2023-08-24T21:01:29.950343763+02:00 level=info msg=“Path Logs” path=/var/log/grafana
logger=settings t=2023-08-24T21:01:29.950401578+02:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2023-08-24T21:01:29.950459374+02:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
logger=settings t=2023-08-24T21:01:29.95051317+02:00 level=info msg=“App mode production”
logger=sqlstore t=2023-08-24T21:01:29.951557626+02:00 level=info msg=“Connecting to DB” dbtype=sqlite3
logger=migrator t=2023-08-24T21:01:30.082888716+02:00 level=info msg=“Starting DB migrations”
logger=migrator t=2023-08-24T21:01:30.125514526+02:00 level=info msg=“migrations completed” performed=0 skipped=493 duration=3.91064ms
logger=secrets t=2023-08-24T21:01:30.130484567+02:00 level=info msg=“Envelope encryption state” enabled=true currentprovider=secretKey.v1
logger=plugin.loader t=2023-08-24T21:01:30.32804994+02:00 level=warn msg=“Plugin missing module.js” pluginID=input warning=“Missing module.js, If you loaded this plugin from git, make sure to compile it.”
logger=plugin.loader t=2023-08-24T21:01:30.328939175+02:00 level=info msg=“Plugin registered” pluginID=input
logger=local.finder t=2023-08-24T21:01:30.329407005+02:00 level=warn msg=“Skipping finding plugins as directory does not exist” path=/var/lib/grafana/plugins
logger=query_data t=2023-08-24T21:01:30.340611875+02:00 level=info msg=“Query Service initialization”
logger=live.push_http t=2023-08-24T21:01:30.359405102+02:00 level=info msg=“Live Push Gateway initialization”
Check if this directory exists /var/lib/grafana/plugins and its permissions.
nope it does not exist (but i’m also not using any external plugins to my knowledge)
Did you follow this documentation when you upgraded?
Update was presented during regular RPi updates
The documentation says that you should run this command after an upgrade:
grafana cli plugins update-all
Nope no change with that command. Downgraded back to 10.0.3 for now
I cant read :pensive:Is it arm? and which one?
Perform standard debugging = increase log level to debug and show Grafana logs from failed login,pls.
I have the same problem. I did an update for my raspberry. The new Version is v10.1.0
I can`t reach the dashboard anymore. I already tried to update the plugins with “sudo grafana-cli plugins update-all”
“grafana-cli plugins ls” tells me → “no installed plugins found”
The service is running. One problem … “Plugin missing module.js”
● grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2023-08-25 08:38:31 CEST; 18s ago
Docs: http://docs.grafana.org
Main PID: 1370 (grafana)
Tasks: 8 (limit: 4915)
CGroup: /system.slice/grafana-server.service
└─1370 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:defaul
Aug 25 08:38:37 raspberrypi-webcam grafana[1370]: logger=settings t=2023-08-25T08:38:37.700561863+02:00 level=info msg=“App mode production”
Aug 25 08:38:37 raspberrypi-webcam grafana[1370]: logger=sqlstore t=2023-08-25T08:38:37.70176627+02:00 level=info msg=“Connecting to DB” dbtype=sqlite3
Aug 25 08:38:37 raspberrypi-webcam grafana[1370]: logger=migrator t=2023-08-25T08:38:37.923904581+02:00 level=info msg=“Starting DB migrations”
Aug 25 08:38:37 raspberrypi-webcam grafana[1370]: logger=migrator t=2023-08-25T08:38:37.98153334+02:00 level=info msg=“migrations completed” performed=0 skipped=493 duration=4.086337ms
Aug 25 08:38:37 raspberrypi-webcam grafana[1370]: logger=secrets t=2023-08-25T08:38:37.986206492+02:00 level=info msg=“Envelope encryption state” enabled=true currentprovider=secretKey.v1
Aug 25 08:38:38 raspberrypi-webcam grafana[1370]: logger=plugin.loader t=2023-08-25T08:38:38.53797539+02:00 level=warn msg=“Plugin missing module.js” pluginID=input warning="Missing module.js, If you loaded this plugin from git, make sure
Aug 25 08:38:38 raspberrypi-webcam grafana[1370]: logger=plugin.loader t=2023-08-25T08:38:38.538537373+02:00 level=info msg=“Plugin registered” pluginID=input
Aug 25 08:38:38 raspberrypi-webcam grafana[1370]: logger=query_data t=2023-08-25T08:38:38.572420827+02:00 level=info msg=“Query Service initialization”
Aug 25 08:38:38 raspberrypi-webcam grafana[1370]: logger=live.push_http t=2023-08-25T08:38:38.585339669+02:00 level=info msg=“Live Push Gateway initialization”
Aug 25 08:38:38 raspberrypi-webcam grafana[1370]: logger=ngalert t=2023-08-25T08:38:38.615049678+02:00 level=warn msg=“Unexpected number of rows updating alert configuration history” rows=0 org=1 hash=8c409350c88d78d2ee938448449e628d
Same problem here, Raspberry Pi, Grafanaupgrade from repo.
Perhaps restoring an backup from /var/lib/grafana/plugin/ may help? Does anybody know or tested this?
I think module.js is missing: /usr/share/grafana/plugins-bundled/internal/input-datasource/module.js
“locate” shows me, that it was still there yesterday, not shure, but cron.daily updates index (updatedb)
But where do we get it from? I can`t find it at Github. I am not at home at the moment. I have to watch for an backup when I am back.
