Grafana not starting after update to 10.1.0
Easiest solution (for the moment) to get Grafana working again is to downgrade: sudo apt-get install grafana=10.0.3
This bug will most certainly be sorted out in the next update.
theres no version 10.0.3 in “my” repo
i opend an issue on github
I did the downgrade. Worked for me! Thanks!
issue still open since yesterday: Grafana-Server crashes with SIGILL after update from 10.0.3 to 10.1.0 on RaspberryPi · Issue #73781 · grafana/grafana · GitHub
Same here, works on 10.0.3 but doesn’t work since 10.0.4 or 10.1.0
grafana-cli plugins remove grafana-image-renderer @ 3.8.0
alexanderzobnin-zabbix-app
not be installed on grafana-10.1.0.-1 Centos
This was the only thing that worked for me. Mine is installed on Debian 11.
same here, after upgrading grafana on my raspberry pi 3 from 10.0.3 → 10.1.0 it did no longer start. only removing it and re-installing 10.0.3 resolved the issue.
Glad no configuration was lost and all dashboards still word.
So is this likely the problem why you cannot perform first login to an instance of v10.1.0 with admin:admin? If so, how can it be fixed?
and trying grafana-cli plugins update-all didn’t make any difference…
