After update to 10.1.4 systemd runs into timeout
Hi there,
after updating to 10.1.4 systemd runs into a timeout but grafana starts and is usable.
Any suggestions?
logger=settings t=2023-10-10T11:22:30.871830259+02:00 level=info msg="Starting Grafana" version=10.1.4 commit=a676a96d91 branch=HEAD compiled=2023-09-29T16:28:45+02:00
logger=settings t=2023-10-10T11:22:30.872492386+02:00 level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-10-10T11:22:30.872576091+02:00 level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-10-10T11:22:30.872607345+02:00 level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-10-10T11:22:30.872652384+02:00 level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-10-10T11:22:30.872716244+02:00 level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-10-10T11:22:30.872752265+02:00 level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-10-10T11:22:30.872778268+02:00 level=info msg=Target target=[all]
logger=settings t=2023-10-10T11:22:30.872818304+02:00 level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-10-10T11:22:30.872843548+02:00 level=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-10-10T11:22:30.87287389+02:00 level=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-10-10T11:22:30.872905465+02:00 level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-10-10T11:22:30.872933733+02:00 level=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-10-10T11:22:30.872962545+02:00 level=info msg="App mode production"
logger=sqlstore t=2023-10-10T11:22:30.873196224+02:00 level=info msg="Connecting to DB" dbtype=postgres
logger=migrator t=2023-10-10T11:22:30.905508624+02:00 level=info msg="Starting DB migrations"
logger=migrator t=2023-10-10T11:22:30.91154794+02:00 level=info msg="migrations completed" performed=0 skipped=493 duration=506.033µs
logger=secrets t=2023-10-10T11:22:30.9145917+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
logger=plugin.loader t=2023-10-10T11:22:30.956442002+02:00 level=warn msg="Plugin missing module.js" pluginID=input warning="Missing module.js, If you loaded this plugin from git, make sure to compile it."
logger=plugin.loader t=2023-10-10T11:22:30.956481868+02:00 level=info msg="Plugin registered" pluginID=input
logger=plugin.loader t=2023-10-10T11:22:31.410594885+02:00 level=info msg="Plugin registered" pluginID=alexanderzobnin-zabbix-app
logger=plugin.loader t=2023-10-10T11:22:31.410747728+02:00 level=info msg="Plugin registered" pluginID=alexanderzobnin-zabbix-datasource
logger=plugin.alexanderzobnin-zabbix-datasource t=2023-10-10T11:22:31.42112433+02:00 level=info msg=Profiler enabled=false
logger=plugin.loader t=2023-10-10T11:22:31.423249639+02:00 level=info msg="Plugin registered" pluginID=alexanderzobnin-zabbix-triggers-panel
logger=plugin.loader t=2023-10-10T11:22:31.423428892+02:00 level=info msg="Plugin registered" pluginID=grafana-opensearch-datasource
logger=plugin.grafana-opensearch-datasource t=2023-10-10T11:22:31.43279454+02:00 level=info msg=Profiler enabled=false
logger=query_data t=2023-10-10T11:22:31.439816555+02:00 level=info msg="Query Service initialization"
logger=live.push_http t=2023-10-10T11:22:31.444913274+02:00 level=info msg="Live Push Gateway initialization"
logger=ngalert t=2023-10-10T11:22:31.464663191+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=5 hash=8c409350c88d78d2ee938448449e628d
logger=ngalert t=2023-10-10T11:22:31.472807457+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=2 hash=8c409350c88d78d2ee938448449e628d
logger=ngalert t=2023-10-10T11:22:31.482507672+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=3 hash=8c409350c88d78d2ee938448449e628d
logger=ngalert t=2023-10-10T11:22:31.489310289+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=4 hash=8c409350c88d78d2ee938448449e628d
logger=ngalert t=2023-10-10T11:22:31.505468877+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=1 hash=not-yet-calculated
logger=ngalert t=2023-10-10T11:22:31.511035588+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=6 hash=e0528a75784033ae7b15c40851d89484
logger=infra.usagestats.collector t=2023-10-10T11:22:33.50152257+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
logger=server t=2023-10-10T11:22:33.502102216+02:00 level=info msg="Writing PID file" path=/var/run/grafana/grafana-server.pid pid=103720
logger=modules t=2023-10-10T11:22:33.503721533+02:00 level=info msg=initialising module=http-server
logger=modules t=2023-10-10T11:22:33.504521176+02:00 level=info msg=initialising module=secret-migrator
logger=http.server t=2023-10-10T11:22:33.507301813+02:00 level=info msg="HTTP Server TLS settings" MinTLSVersion=TLS1.2 configuredciphers=TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA,TLS_RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_256_GCM_SHA384,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_256_CBC_SHA
logger=http.server t=2023-10-10T11:22:33.507700517+02:00 level=info msg="HTTP Server Listen" address=[::]:443 protocol=https subUrl= socket=
logger=modules t=2023-10-10T11:22:33.510819661+02:00 level=info msg=initialising module=provisioning
logger=provisioning.alerting t=2023-10-10T11:22:33.511186403+02:00 level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2023-10-10T11:22:33.511209381+02:00 level=info msg="finished to provision alerting"
logger=modules t=2023-10-10T11:22:33.511390439+02:00 level=info msg=initialising module=background-services
logger=modules t=2023-10-10T11:22:33.511651043+02:00 level=info msg="All modules healthy" modules="[background-services http-server secret-migrator provisioning]"
logger=ngalert.state.manager t=2023-10-10T11:22:33.511714107+02:00 level=info msg="Warming state cache for startup"
logger=grafanaStorageLogger t=2023-10-10T11:22:33.512117422+02:00 level=info msg="storage starting"
logger=ngalert.state.manager t=2023-10-10T11:22:33.518903952+02:00 level=info msg="State cache has been initialized" states=0 duration=7.188531ms
logger=ngalert.scheduler t=2023-10-10T11:22:33.518986024+02:00 level=info msg="Starting scheduler" tickInterval=10s
logger=ticker t=2023-10-10T11:22:33.519046689+02:00 level=info msg=starting first_tick=2023-10-10T11:22:40+02:00
logger=ngalert.multiorg.alertmanager t=2023-10-10T11:22:33.5190976+02:00 level=info msg="Starting MultiOrg Alertmanager"
logger=grafana.update.checker t=2023-10-10T11:22:33.549852851+02:00 level=info msg="Update check succeeded" duration=37.656806ms
logger=plugins.update.checker t=2023-10-10T11:22:33.564982295+02:00 level=info msg="Update check succeeded" duration=52.34187ms
logger=context userId=36 orgId=1 uname=benner t=2023-10-10T11:22:33.774275048+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.38.190 time_ms=4 duration=4.965576ms size=0 referer= handler=/api/live/ws
logger=live t=2023-10-10T11:22:33.787770085+02:00 level=info msg="Initialized channel handler" channel=grafana/dashboard/uid/aRosuSdZz address=grafana/dashboard/uid/aRosuSdZz
logger=context userId=8 orgId=1 uname=dohmen t=2023-10-10T11:22:34.419408103+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.32.47 time_ms=7 duration=7.231374ms size=0 referer= handler=/api/live/ws
logger=authn.service t=2023-10-10T11:22:34.686475961+02:00 level=warn msg="Failed to run post auth hook" client=auth.client.session id=user:8 error="[user.sync.fetch] failed to resolve user: context canceled"
logger=authn.anonymous t=2023-10-10T11:22:34.687324707+02:00 level=error msg="failed to find organization" name=Anonymous error="context canceled"
logger=authn.service t=2023-10-10T11:22:34.687410989+02:00 level=warn msg="Failed to authenticate request" client=auth.client.anonymous error="context canceled"
logger=authn.service t=2023-10-10T11:22:34.691189801+02:00 level=warn msg="Failed to run post auth hook" client=auth.client.session id=user:8 error="[user.sync.fetch] failed to resolve user: context canceled"
logger=authn.anonymous t=2023-10-10T11:22:34.691313554+02:00 level=error msg="failed to find organization" name=Anonymous error="context canceled"
logger=authn.service t=2023-10-10T11:22:34.691355521+02:00 level=warn msg="Failed to authenticate request" client=auth.client.anonymous error="context canceled"
logger=authn.service t=2023-10-10T11:22:34.695797648+02:00 level=warn msg="Failed to authenticate request" client=auth.client.session error="pq: storniere Anfrage wegen Benutzeraufforderung"
logger=authn.anonymous t=2023-10-10T11:22:34.695859738+02:00 level=error msg="failed to find organization" name=Anonymous error="context canceled"
logger=authn.service t=2023-10-10T11:22:34.695870635+02:00 level=warn msg="Failed to authenticate request" client=auth.client.anonymous error="context canceled"
logger=context userId=57 orgId=5 uname=lux t=2023-10-10T11:22:40.524548692+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.32.34 time_ms=7 duration=7.78352ms size=0 referer= handler=/api/live/ws
logger=context userId=-1 orgId=2 uname= t=2023-10-10T11:22:47.56229729+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.37.107 time_ms=3 duration=3.278821ms size=0 referer= handler=/api/live/ws
logger=context userId=8 orgId=1 uname=dohmen t=2023-10-10T11:22:58.814081965+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.32.47 time_ms=4 duration=4.60122ms size=0 referer= handler=/api/live/ws
logger=context userId=8 orgId=1 uname=dohmen t=2023-10-10T11:23:05.11026241+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=192.168.32.47 time_ms=4 duration=4.536154ms size=0 referer= handler=/api/live/ws
logger=live t=2023-10-10T11:23:05.279047003+02:00 level=info msg="Initialized channel handler" channel=grafana/dashboard/uid/XOyxlbm7z address=grafana/dashboard/uid/XOyxlbm7z
logger=live t=2023-10-10T11:23:11.510706469+02:00 level=info msg="Initialized channel handler" channel=grafana/dashboard/uid/QpOa32Q4z address=grafana/dashboard/uid/QpOa32Q4z
br
Regarding to this topic:
When i change the systemd type from notify to simple, everything starts up correct.
Is it just an upgrade issue or something else?
