Dear all,
unfortunately my Grafana Web-UI is not working after update from 10.0.3 to 10.1.0. If I try to access the xxx.xxx.xxx.xxx:3000 I get only page is not available (ERR_CONNECTION_REFUSED)
It is running on a Raspberry PI 4 - Raspberry Pi OS bullseye 32bit with latest updates.
Grafana.log
logger=settings t=2023-08-25T08:01:50.889677541+02:00 level=info msg="Starting Grafana" version=10.1.0 commit=838218ba20 branch=HEAD compiled=2023-08-23T12:52:21+02:00
logger=settings t=2023-08-25T08:01:50.892494545+02:00 level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-08-25T08:01:50.893073687+02:00 level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2023-08-25T08:01:50.89561788+02:00 level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2023-08-25T08:01:50.895715119+02:00 level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2023-08-25T08:01:50.895813229+02:00 level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2023-08-25T08:01:50.895876025+02:00 level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2023-08-25T08:01:50.895934617+02:00 level=info msg=Target target=[all]
logger=settings t=2023-08-25T08:01:50.896028004+02:00 level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-08-25T08:01:50.8960858+02:00 level=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-08-25T08:01:50.896140522+02:00 level=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-08-25T08:01:50.89619504+02:00 level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-08-25T08:01:50.896250743+02:00 level=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-08-25T08:01:50.896307816+02:00 level=info msg="App mode production"
logger=sqlstore t=2023-08-25T08:01:50.897365896+02:00 level=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2023-08-25T08:01:51.024317379+02:00 level=info msg="Starting DB migrations"
logger=migrator t=2023-08-25T08:01:51.06285462+02:00 level=info msg="migrations completed" performed=0 skipped=493 duration=3.92551ms
logger=secrets t=2023-08-25T08:01:51.06703059+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
logger=plugin.loader t=2023-08-25T08:01:51.240196373+02:00 level=warn msg="Plugin missing module.js" pluginID=input warning="Missing module.js, If you loaded this plugin from git, make sure to compile it."
logger=plugin.loader t=2023-08-25T08:01:51.240377371+02:00 level=info msg="Plugin registered" pluginID=input
logger=plugin.loader t=2023-08-25T08:01:51.899793238+02:00 level=info msg="Plugin registered" pluginID=natel-discrete-panel
logger=query_data t=2023-08-25T08:01:51.911278828+02:00 level=info msg="Query Service initialization"
logger=live.push_http t=2023-08-25T08:01:51.922536087+02:00 level=info msg="Live Push Gateway initialization"
logger=ngalert t=2023-08-25T08:01:51.946570755+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=1 hash=not-yet-calculated
logger=infra.usagestats.collector t=2023-08-25T08:02:02.378306008+02:00 level=info msg="registering usage stat providers" usageStatsProvidersLen=2
logger=server t=2023-08-25T08:02:02.379844176+02:00 level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=21279
logger=modules t=2023-08-25T08:02:02.381197493+02:00 level=info msg=initialising module=secret-migrator
logger=modules t=2023-08-25T08:02:02.38120916+02:00 level=info msg=initialising module=http-server
logger=http.server t=2023-08-25T08:02:02.389674062+02:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
logger=modules t=2023-08-25T08:02:02.397232382+02:00 level=info msg=initialising module=provisioning
logger=provisioning.alerting t=2023-08-25T08:02:02.398860901+02:00 level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2023-08-25T08:02:02.398993751+02:00 level=info msg="finished to provision alerting"
logger=modules t=2023-08-25T08:02:02.399208452+02:00 level=info msg=initialising module=background-services
logger=modules t=2023-08-25T08:02:02.399997647+02:00 level=info msg="All modules healthy" modules="[secret-migrator provisioning http-server background-services]"
logger=ngalert.state.manager t=2023-08-25T08:02:02.400576974+02:00 level=info msg="Warming state cache for startup"
logger=grafanaStorageLogger t=2023-08-25T08:02:02.401551814+02:00 level=info msg="storage starting"
logger=ngalert.state.manager t=2023-08-25T08:02:02.405233161+02:00 level=info msg="State cache has been initialized" states=0 duration=4.623466ms
logger=ngalert.scheduler t=2023-08-25T08:02:02.405517361+02:00 level=info msg="Starting scheduler" tickInterval=10s
logger=ticker t=2023-08-25T08:02:02.406208538+02:00 level=info msg=starting first_tick=2023-08-25T08:02:10+02:00
logger=ngalert.multiorg.alertmanager t=2023-08-25T08:02:02.40673594+02:00 level=info msg="Starting MultiOrg Alertmanager"
logger=grafana.update.checker t=2023-08-25T08:02:02.619812889+02:00 level=info msg="Update check succeeded" duration=218.16028ms
logger=plugins.update.checker t=2023-08-25T08:02:02.643695003+02:00 level=info msg="Update check succeeded" duration=239.351498ms
systemctl status grafana-server
β grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2023-08-25 08:04:47 CEST; 34s ago
Docs: http://docs.grafana.org
Main PID: 21504 (grafana)
Tasks: 11 (limit: 4915)
CPU: 14.035s
CGroup: /system.slice/grafana-server.service
ββ21504 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/et>
Aug 25 08:04:59 pihole grafana[21504]: logger=modules t=2023-08-25T08:04:59.822433898+02:00 level=info msg=initialising module=background-services
Aug 25 08:04:59 pihole grafana[21504]: logger=modules t=2023-08-25T08:04:59.822711469+02:00 level=info msg="All modules healthy" modules="[http-server secret-migrator provisioning background-services]"
Aug 25 08:04:59 pihole grafana[21504]: logger=ngalert.state.manager t=2023-08-25T08:04:59.822697784+02:00 level=info msg="Warming state cache for startup"
Aug 25 08:04:59 pihole grafana[21504]: logger=ngalert.state.manager t=2023-08-25T08:04:59.824265377+02:00 level=info msg="State cache has been initialized" states=0 duration=1.558612ms
Aug 25 08:04:59 pihole grafana[21504]: logger=ngalert.scheduler t=2023-08-25T08:04:59.824469948+02:00 level=info msg="Starting scheduler" tickInterval=10s
Aug 25 08:04:59 pihole grafana[21504]: logger=ticker t=2023-08-25T08:04:59.824672576+02:00 level=info msg=starting first_tick=2023-08-25T08:05:00+02:00
Aug 25 08:04:59 pihole grafana[21504]: logger=ngalert.multiorg.alertmanager t=2023-08-25T08:04:59.824843574+02:00 level=info msg="Starting MultiOrg Alertmanager"
Aug 25 08:04:59 pihole grafana[21504]: logger=grafanaStorageLogger t=2023-08-25T08:04:59.825170996+02:00 level=info msg="storage starting"
Aug 25 08:05:00 pihole grafana[21504]: logger=grafana.update.checker t=2023-08-25T08:05:00.021626696+02:00 level=info msg="Update check succeeded" duration=193.637771ms
Aug 25 08:05:00 pihole grafana[21504]: logger=plugins.update.checker t=2023-08-25T08:05:00.043879528+02:00 level=info msg="Update check succeeded" duration=214.441415ms
netstat -tulpn | grep grafana
tcp6 0 0 :::3000 :::* LISTEN 21588/grafana
curl -vL http://localhost:3000
* Trying ::1:3000...
* connect to ::1 port 3000 failed: Verbindungsaufbau abgelehnt
* Trying 127.0.0.1:3000...
* connect to 127.0.0.1 port 3000 failed: Verbindungsaufbau abgelehnt
* Failed to connect to localhost port 3000: Verbindungsaufbau abgelehnt
* Closing connection 0
curl: (7) Failed to connect to localhost port 3000: Verbindungsaufbau abgelehnt
Is there anyone who can support me on that problem?
Thanks in advance.
Best regards
Foradh
