Hello, I’m having issues accessing the Grafana Web Gui after installing and Starting the grafana-server.
I’m new to this so bear with me in the information I provide.
-Version 9.2.10 -
-Access to the webpage via localhost:3000 -
-I did a fresh install of grafana on RHEL 9.4
-I followed the grafana instructions to install for my OS. -
What happened?
-I attempted to access the Grafana main page using HTTP://x.x.x.x:3000
-IT hung and didn’t load the main page. -
-I expected the main default login page to load. -
-The configuration has been left as default in /etc/grafana/grafana.ini -
logger=cleanup t=2024-09-25T00:05:24.919429353-05:00 level=info msg=“Completed cleanup jobs” duration=5.343549ms
logger=cleanup t=2024-09-25T00:15:24.918720461-05:00 level=info msg=“Completed cleanup jobs” duration=4.652676ms
logger=cleanup t=2024-09-25T00:25:24.920007323-05:00 level=info msg=“Completed cleanup jobs” duration=5.654351ms
logger=cleanup t=2024-09-25T00:35:24.977865743-05:00 level=info msg=“Completed cleanup jobs” duration=64.231575ms
logger=cleanup t=2024-09-25T00:45:24.920258203-05:00 level=info msg=“Completed cleanup jobs” duration=6.080939ms
logger=cleanup t=2024-09-25T00:55:24.918639764-05:00 level=info msg=“Completed cleanup jobs” duration=4.440432ms
logger=cleanup t=2024-09-25T01:05:24.918271459-05:00 level=info msg=“Completed cleanup jobs” duration=4.556879ms
logger=cleanup t=2024-09-25T01:15:24.980751876-05:00 level=info msg=“Completed cleanup jobs” duration=67.340813ms
logger=cleanup t=2024-09-25T01:25:24.980557084-05:00 level=info msg=“Completed cleanup jobs” duration=66.527265ms
logger=cleanup t=2024-09-25T01:35:24.982870322-05:00 level=info msg=“Completed cleanup jobs” duration=68.614453ms
logger=cleanup t=2024-09-25T01:45:24.983081673-05:00 level=info msg=“Completed cleanup jobs” duration=68.952623ms
logger=cleanup t=2024-09-25T01:55:24.917582952-05:00 level=info msg=“Completed cleanup jobs” duration=3.969965ms
logger=cleanup t=2024-09-25T02:05:24.919942702-05:00 level=info msg=“Completed cleanup jobs” duration=6.480891ms
logger=cleanup t=2024-09-25T02:15:24.918879199-05:00 level=info msg=“Completed cleanup jobs” duration=4.834144ms
logger=cleanup t=2024-09-25T02:25:24.920093548-05:00 level=info msg=“Completed cleanup jobs” duration=5.919317ms
logger=cleanup t=2024-09-25T02:35:24.920180685-05:00 level=info msg=“Completed cleanup jobs” duration=6.383765ms
logger=cleanup t=2024-09-25T02:45:24.920554868-05:00 level=info msg=“Completed cleanup jobs” duration=6.609293ms
logger=cleanup t=2024-09-25T02:55:24.979602621-05:00 level=info msg=“Completed cleanup jobs” duration=65.635428ms
logger=cleanup t=2024-09-25T03:05:24.978882259-05:00 level=info msg=“Completed cleanup jobs” duration=65.539019ms
logger=cleanup t=2024-09-25T03:15:24.981134914-05:00 level=info msg=“Completed cleanup jobs” duration=67.272013ms
logger=cleanup t=2024-09-25T03:25:24.920343815-05:00 level=info msg=“Completed cleanup jobs” duration=6.173305ms
logger=cleanup t=2024-09-25T03:35:24.97842097-05:00 level=info msg=“Completed cleanup jobs” duration=64.641923ms
logger=cleanup t=2024-09-25T03:45:24.921208372-05:00 level=info msg=“Completed cleanup jobs” duration=7.32775ms
logger=cleanup t=2024-09-25T03:55:24.979484681-05:00 level=info msg=“Completed cleanup jobs” duration=65.678904ms
logger=cleanup t=2024-09-25T04:05:24.920068318-05:00 level=info msg=“Completed cleanup jobs” duration=5.765447ms
logger=cleanup t=2024-09-25T04:15:24.918702443-05:00 level=info msg=“Completed cleanup jobs” duration=4.908582ms
logger=cleanup t=2024-09-25T04:25:24.978455591-05:00 level=info msg=“Completed cleanup jobs” duration=64.556842ms
logger=cleanup t=2024-09-25T04:35:24.978795927-05:00 level=info msg=“Completed cleanup jobs” duration=64.502247ms
logger=cleanup t=2024-09-25T04:45:24.918771816-05:00 level=info msg=“Completed cleanup jobs” duration=4.851062ms
logger=cleanup t=2024-09-25T04:55:24.920307451-05:00 level=info msg=“Completed cleanup jobs” duration=6.099953ms
logger=cleanup t=2024-09-25T05:05:24.978111068-05:00 level=info msg=“Completed cleanup jobs” duration=64.805307ms
logger=cleanup t=2024-09-25T05:15:24.978334272-05:00 level=info msg=“Completed cleanup jobs” duration=64.439384ms
logger=cleanup t=2024-09-25T05:25:24.9807602-05:00 level=info msg=“Completed cleanup jobs” duration=66.662834ms
logger=cleanup t=2024-09-25T05:35:24.983303315-05:00 level=info msg=“Completed cleanup jobs” duration=69.200118ms
logger=cleanup t=2024-09-25T05:45:24.982119112-05:00 level=info msg=“Completed cleanup jobs” duration=68.324287ms
logger=cleanup t=2024-09-25T05:55:24.918120617-05:00 level=info msg=“Completed cleanup jobs” duration=4.638882ms
logger=cleanup t=2024-09-25T06:05:24.98640353-05:00 level=info msg=“Completed cleanup jobs” duration=72.220036ms
logger=cleanup t=2024-09-25T06:15:24.918840584-05:00 level=info msg=“Completed cleanup jobs” duration=5.130746ms
logger=cleanup t=2024-09-25T06:25:24.920817715-05:00 level=info msg=“Completed cleanup jobs” duration=6.943355ms
logger=cleanup t=2024-09-25T06:35:24.979634636-05:00 level=info msg=“Completed cleanup jobs” duration=65.627008ms
logger=cleanup t=2024-09-25T06:45:24.980594897-05:00 level=info msg=“Completed cleanup jobs” duration=66.679406ms
logger=cleanup t=2024-09-25T06:55:24.922194391-05:00 level=info msg=“Completed cleanup jobs” duration=8.241975ms
logger=cleanup t=2024-09-25T07:05:24.980913265-05:00 level=info msg=“Completed cleanup jobs” duration=66.91299ms
logger=cleanup t=2024-09-25T07:15:24.978733582-05:00 level=info msg=“Completed cleanup jobs” duration=64.885715ms
logger=cleanup t=2024-09-25T07:25:24.980283193-05:00 level=info msg=“Completed cleanup jobs” duration=66.445094ms
logger=cleanup t=2024-09-25T07:35:24.980462814-05:00 level=info msg=“Completed cleanup jobs” duration=66.263444ms
logger=cleanup t=2024-09-25T07:45:24.980254442-05:00 level=info msg=“Completed cleanup jobs” duration=66.898594ms
logger=cleanup t=2024-09-25T07:55:24.979998533-05:00 level=info msg=“Completed cleanup jobs” duration=66.683205ms
logger=cleanup t=2024-09-25T08:05:24.979569368-05:00 level=info msg=“Completed cleanup jobs” duration=66.160687ms
logger=cleanup t=2024-09-25T08:15:24.919047943-05:00 level=info msg=“Completed cleanup jobs” duration=5.200088ms
logger=cleanup t=2024-09-25T08:25:24.980146741-05:00 level=info msg=“Completed cleanup jobs” duration=66.390335ms
logger=cleanup t=2024-09-25T08:35:24.922919241-05:00 level=info msg=“Completed cleanup jobs” duration=8.964791ms
logger=cleanup t=2024-09-25T08:45:24.921051821-05:00 level=info msg=“Completed cleanup jobs” duration=7.109366ms
logger=cleanup t=2024-09-25T08:55:24.981183764-05:00 level=info msg=“Completed cleanup jobs” duration=67.370844ms
logger=cleanup t=2024-09-25T09:05:24.91990318-05:00 level=info msg=“Completed cleanup jobs” duration=6.258949ms
logger=cleanup t=2024-09-25T09:15:24.97861122-05:00 level=info msg=“Completed cleanup jobs” duration=64.756476ms
logger=cleanup t=2024-09-25T09:25:24.918542475-05:00 level=info msg=“Completed cleanup jobs” duration=4.979185ms
logger=cleanup t=2024-09-25T09:35:24.982890247-05:00 level=info msg=“Completed cleanup jobs” duration=68.812242ms
logger=cleanup t=2024-09-25T09:45:24.920043495-05:00 level=info msg=“Completed cleanup jobs” duration=5.871578ms
logger=cleanup t=2024-09-25T09:55:24.922949176-05:00 level=info msg=“Completed cleanup jobs” duration=8.818213ms
logger=sqlstore.transactions t=2024-09-25T09:55:24.925805673-05:00 level=info msg=“Database locked, sleeping then retrying” error=“database is locked” retry=0
logger=cleanup t=2024-09-25T10:05:24.919663234-05:00 level=info msg=“Completed cleanup jobs” duration=5.964903ms
logger=cleanup t=2024-09-25T10:15:24.979327834-05:00 level=info msg=“Completed cleanup jobs” duration=65.350387ms
logger=cleanup t=2024-09-25T10:25:24.980710007-05:00 level=info msg=“Completed cleanup jobs” duration=66.451264ms
logger=cleanup t=2024-09-25T10:35:24.980303678-05:00 level=info msg=“Completed cleanup jobs” duration=66.492056ms
logger=cleanup t=2024-09-25T10:45:24.923472932-05:00 level=info msg=“Completed cleanup jobs” duration=9.618875ms
logger=cleanup t=2024-09-25T10:55:24.919743046-05:00 level=info msg=“Completed cleanup jobs” duration=5.515692ms
logger=cleanup t=2024-09-25T11:05:24.921638634-05:00 level=info msg=“Completed cleanup jobs” duration=7.50551ms
logger=cleanup t=2024-09-25T11:15:24.978824057-05:00 level=info msg=“Completed cleanup jobs” duration=65.130987ms
logger=cleanup t=2024-09-25T11:25:24.978185565-05:00 level=info msg=“Completed cleanup jobs” duration=64.298362ms
logger=cleanup t=2024-09-25T11:35:24.979614075-05:00 level=info msg=“Completed cleanup jobs” duration=65.293199ms
logger=cleanup t=2024-09-25T11:45:24.984406327-05:00 level=info msg=“Completed cleanup jobs” duration=70.203245ms
logger=cleanup t=2024-09-25T11:55:24.980632722-05:00 level=info msg=“Completed cleanup jobs” duration=66.650904ms
logger=cleanup t=2024-09-25T12:05:24.981036805-05:00 level=info msg=“Completed cleanup jobs” duration=66.768772ms
logger=cleanup t=2024-09-25T12:15:24.918645471-05:00 level=info msg=“Completed cleanup jobs” duration=4.616096ms
logger=cleanup t=2024-09-25T12:25:24.919593707-05:00 level=info msg=“Completed cleanup jobs” duration=5.758822ms
logger=cleanup t=2024-09-25T12:35:24.921980495-05:00 level=info msg=“Completed cleanup jobs” duration=7.905056ms
logger=cleanup t=2024-09-25T12:45:24.981289604-05:00 level=info msg=“Completed cleanup jobs” duration=67.322788ms
logger=cleanup t=2024-09-25T12:55:24.980347643-05:00 level=info msg=“Completed cleanup jobs” duration=66.359174ms
logger=cleanup t=2024-09-25T13:05:24.918559548-05:00 level=info msg=“Completed cleanup jobs” duration=4.665781ms
logger=cleanup t=2024-09-25T13:15:24.980138138-05:00 level=info msg=“Completed cleanup jobs” duration=66.169011ms
logger=cleanup t=2024-09-25T13:25:24.920630212-05:00 level=info msg=“Completed cleanup jobs” duration=6.633283ms
logger=cleanup t=2024-09-25T13:35:24.981463259-05:00 level=info msg=“Completed cleanup jobs” duration=67.186059ms
logger=cleanup t=2024-09-25T13:45:24.979455819-05:00 level=info msg=“Completed cleanup jobs” duration=65.470558ms
logger=cleanup t=2024-09-25T13:55:24.997857551-05:00 level=info msg=“Completed cleanup jobs” duration=84.263779ms
logger=cleanup t=2024-09-25T14:05:24.980180469-05:00 level=info msg=“Completed cleanup jobs” duration=66.140786ms
logger=cleanup t=2024-09-25T14:15:24.979126557-05:00 level=info msg=“Completed cleanup jobs” duration=65.113365ms
logger=server t=2024-09-25T14:17:30.013990783-05:00 level=info msg=“Shutdown started” reason=“System signal: terminated”
logger=ticker t=2024-09-25T14:17:30.014194845-05:00 level=info msg=stopped last_tick=2024-09-25T14:17:30-05:00
logger=tracing t=2024-09-25T14:17:30.014408564-05:00 level=info msg=“Closing tracing”
logger=settings t=2024-09-25T14:48:13.473569187-05:00 level=info msg=“Starting Grafana” version=9.2.10 commit=NA branch=main compiled=2024-04-15T19:00:00-05:00
logger=settings t=2024-09-25T14:48:13.476634283-05:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2024-09-25T14:48:13.476677827-05:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2024-09-25T14:48:13.476706843-05:00 level=info msg=“Config overridden from command line” arg=“default.paths.data=/var/lib/grafana”
logger=settings t=2024-09-25T14:48:13.476720326-05:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
logger=settings t=2024-09-25T14:48:13.476728229-05:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
logger=settings t=2024-09-25T14:48:13.476736857-05:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
logger=settings t=2024-09-25T14:48:13.476745388-05:00 level=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2024-09-25T14:48:13.476753103-05:00 level=info msg=“Path Data” path=/var/lib/grafana
logger=settings t=2024-09-25T14:48:13.476760552-05:00 level=info msg=“Path Logs” path=/var/log/grafana
logger=settings t=2024-09-25T14:48:13.476770718-05:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2024-09-25T14:48:13.476795869-05:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
logger=settings t=2024-09-25T14:48:13.476806994-05:00 level=info msg=“App mode production”
logger=sqlstore t=2024-09-25T14:48:13.479830669-05:00 level=info msg=“Connecting to DB” dbtype=sqlite3
logger=migrator t=2024-09-25T14:48:13.55344209-05:00 level=info msg=“Starting DB migrations”
logger=migrator t=2024-09-25T14:48:13.574689439-05:00 level=info msg=“migrations completed” performed=0 skipped=452 duration=1.128433ms
logger=plugin.loader t=2024-09-25T14:48:13.759510172-05:00 level=info msg=“Plugin registered” pluginID=input
logger=plugin.signature.validator t=2024-09-25T14:48:13.776785277-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=pcp-breadcrumbs-panel pluginDir=/usr/share/performancecopilot-pcp-app/panels/breadcrumbs
logger=plugin.signature.validator t=2024-09-25T14:48:13.777024387-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=pcp-flamegraph-panel pluginDir=/usr/share/performancecopilot-pcp-app/panels/flamegraph
logger=plugin.signature.validator t=2024-09-25T14:48:13.777127506-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=pcp-troubleshooting-panel pluginDir=/usr/share/performancecopilot-pcp-app/panels/troubleshooting
logger=plugin.signature.validator t=2024-09-25T14:48:13.777222464-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=performancecopilot-pcp-app pluginDir=/usr/share/performancecopilot-pcp-app
logger=plugin.signature.validator t=2024-09-25T14:48:13.796051025-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=pcp-bpftrace-datasource pluginDir=/usr/share/performancecopilot-pcp-app/datasources/bpftrace
logger=plugin.signature.validator t=2024-09-25T14:48:13.796287204-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=pcp-redis-datasource pluginDir=/usr/share/performancecopilot-pcp-app/datasources/redis
logger=plugin.signature.validator t=2024-09-25T14:48:13.796407922-05:00 level=warn msg=“Permitting unsigned plugin. This is not recommended” pluginID=pcp-vector-datasource pluginDir=/usr/share/performancecopilot-pcp-app/datasources/vector
logger=plugin.loader t=2024-09-25T14:48:13.796541315-05:00 level=info msg=“Plugin registered” pluginID=pcp-breadcrumbs-panel
logger=plugin.loader t=2024-09-25T14:48:13.796760205-05:00 level=info msg=“Plugin registered” pluginID=pcp-flamegraph-panel
logger=plugin.loader t=2024-09-25T14:48:13.796833165-05:00 level=info msg=“Plugin registered” pluginID=pcp-troubleshooting-panel
logger=plugin.loader t=2024-09-25T14:48:13.796890496-05:00 level=info msg=“Plugin registered” pluginID=performancecopilot-pcp-app
logger=plugin.loader t=2024-09-25T14:48:13.796955579-05:00 level=info msg=“Plugin registered” pluginID=pcp-bpftrace-datasource
logger=plugin.loader t=2024-09-25T14:48:13.79700981-05:00 level=info msg=“Plugin registered” pluginID=pcp-redis-datasource
logger=plugin.loader t=2024-09-25T14:48:13.935739864-05:00 level=info msg=“Plugin registered” pluginID=pcp-vector-datasource
logger=secrets t=2024-09-25T14:48:13.935835157-05:00 level=info msg=“Envelope encryption state” enabled=true currentprovider=secretKey.v1
logger=query_data t=2024-09-25T14:48:13.9455606-05:00 level=info msg=“Query Service initialization”
logger=live.push_http t=2024-09-25T14:48:13.953879885-05:00 level=info msg=“Live Push Gateway initialization”
logger=infra.usagestats.collector t=2024-09-25T14:48:14.099103573-05:00 level=info msg=“registering usage stat providers” usageStatsProvidersLen=2
logger=server t=2024-09-25T14:48:14.099294762-05:00 level=info msg=“Writing PID file” path=/var/run/grafana/grafana-server.pid pid=5893
logger=provisioning.alerting t=2024-09-25T14:48:14.09961248-05:00 level=error msg=“can’t read alerting provisioning files from directory” path=/etc/grafana/provisioning/alerting error=“open /etc/grafana/provisioning/alerting: no such file or directory”
logger=provisioning.alerting t=2024-09-25T14:48:14.099641653-05:00 level=info msg=“starting to provision alerting”
logger=provisioning.alerting t=2024-09-25T14:48:14.099661701-05:00 level=info msg=“finished to provision alerting”
logger=http.server t=2024-09-25T14:48:14.112674043-05:00 level=info msg=“HTTP Server Listen” address=[::]:3000 protocol=http subUrl= socket=
logger=ngalert t=2024-09-25T14:48:14.113989464-05:00 level=info msg=“warming cache for startup”
logger=grafanaStorageLogger t=2024-09-25T14:48:14.119520203-05:00 level=info msg=“storage starting”
logger=ticker t=2024-09-25T14:48:14.12392874-05:00 level=info msg=starting first_tick=2024-09-25T14:48:20-05:00
logger=ngalert.multiorg.alertmanager t=2024-09-25T14:48:14.124021948-05:00 level=info msg=“starting MultiOrg Alertmanager”
logger=cleanup t=2024-09-25T14:58:14.128540461-05:00 level=info msg=“Completed cleanup jobs” duration=7.831239ms
logger=cleanup t=2024-09-25T15:08:14.125020826-05:00 level=info msg=“Completed cleanup jobs” duration=4.811354ms
logger=cleanup t=2024-09-25T15:18:14.188030744-05:00 level=info msg=“Completed cleanup jobs” duration=67.907813ms -
-Install Grafana on RHEL or Fedora | Grafana documentation
