How to access the Web UI of grafana
    centos 3.10.0-1160.el7.x86_64 (7.9)
    grafana 11.5.2-1
    I hope to monitor the exporter like as node, ib, dcgmi.
    Just installed a grafana rpm on the local system.
  • What happened?
    I can’t access the web ui of grafana.
    [root@master02 grafana]# grep [1] grafana.ini
    protocol = http
    serve_from_sub_path = true
    level = debug
    disabled_labels =
    max_age =
    max_annotations_to_keep =
    enabled = false
    timeout = 30s
curl commands
[root@master02 grafana]# curl -vL http://localhost:3000
  • About to connect() to localhost port 3000 (#0)
  • Trying ::1…
  • Connected to localhost (::1) port 3000 (#0)
GET / HTTP/1.1
User-Agent: curl/7.29.0
Host: localhost:3000
Accept: /
< HTTP/1.1 302 Found
< Cache-Control: no-store
< Content-Type: text/html; charset=utf-8
< Location: /login
< X-Content-Type-Options: nosniff
< X-Frame-Options: deny
< X-Xss-Protection: 1; mode=block
< Date: Tue, 11 Mar 2025 06:00:41 GMT
< Content-Length: 29
  • Ignoring the response-body
  • Connection #0 to host localhost left intact
  • Issue another request to this URL: ‘http://localhost:3000/login’
  • Found bundle for host localhost: 0xc34ec0
  • Re-using existing connection! (#0) with host localhost
GET /login HTTP/1.1
Accept: /
< HTTP/1.1 200 OK
< Content-Type: text/html; charset=UTF-8
< Transfer-Encoding: chunked
<meta charset="utf-8" />
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
<meta name="viewport" content="width=device-width" />
<meta name="theme-color" content="#000" />
<title>Grafana</title>
<base href="/" />
<link rel="icon" type="image/png" href="public/img/fav32.png" />
<link rel="apple-touch-icon" sizes="180x180" href="public/img/apple-touch-icon.png" />
<link rel="mask-icon" href="public/img/grafana_mask_icon.svg" color="#F05A28" />
  <link rel="stylesheet" href="public/build/grafana.app.ad2ed81beeec71531a35.css" />
<link rel="stylesheet" href="public/build/grafana.dark.23c5425b7a9e1580d499.css" />
<script nonce="">
  performance.mark('frontend_boot_css_time_seconds');
</script>
<meta name="mobile-web-app-capable" content="yes" />
<meta name="apple-mobile-web-app-status-bar-style" content="black" />
<meta name="msapplication-TileColor" content="#2b5797" />
<meta name="msapplication-config" content="public/img/browserconfig.xml" />
.preloader { height: 100%; flex-direction: column; display: flex; justify-content: center; align-items: center; margin: 0 32px; }
  .preloader__enter {
    opacity: 0;
    animation-name: preloader-fade-in;
    animation-iteration-count: 1;
    animation-duration: 0.9s;
    animation-delay: 0.5s;
    animation-fill-mode: forwards;
  .preloader__bounce {
    text-align: center;
    animation-name: preloader-bounce;
    animation-iteration-count: infinite;
  .preloader__logo {
    display: inline-block;
    animation-name: preloader-squash;
    width: 60px;
    height: 60px;
    background-repeat: no-repeat;
    background-size: contain;
    background-image: url('public/img/grafana_icon.svg');
  .preloader__text {
    margin-top: 16px;
    font-weight: 500;
    font-size: 14px;
    font-family: Sans-serif;
    opacity: 0;
  .theme-light .preloader__text {
    color: #52545c;
  .theme-dark .preloader__text {
    color: #d8d9da;
  @keyframes preloader-fade-in {
    0% {
      opacity: 0;
      animation-timing-function: cubic-bezier(0, 0, 0.5, 1);
    100% {
      opacity: 1;
  @keyframes preloader-bounce {
    from,
    to {
      transform: translateY(0px);
      animation-timing-function: cubic-bezier(0.3, 0, 0.1, 1);
    50% {
      transform: translateY(-50px);
      animation-timing-function: cubic-bezier(0.9, 0, 0.7, 1);
  @keyframes preloader-squash {
    0% {
      transform: scaleX(1.3) scaleY(0.8);
    15% {
      transform: scaleX(0.75) scaleY(1.25);
      animation-timing-function: cubic-bezier(0, 0, 0.7, 0.75);
    55% {
      transform: scaleX(1.05) scaleY(0.95);
      animation-timing-function: cubic-bezier(0.9, 0, 1, 1);
    95% {
      animation-timing-function: cubic-bezier(0, 0, 0, 1);
    100% {
      animation-timing-function: cubic-bezier(0, 0, 0.7, 1);
  .preloader__text--fail {
    display: none;
  .preloader--done .preloader__bounce,
  .preloader--done .preloader__logo {
    animation-name: none;
    display: none;
  .preloader--done .preloader__logo,
  .preloader--done .preloader__text {
    display: none;
    color: #ff5705 !important;
    font-size: 15px;
  .theme-light .preloader--done .preloader__text {
    color: #52545c !important;
  .preloader--done .preloader__text--fail {
    display: block;
  .preloader--done .preloader__text--fail a {
    color: white;
  .theme-light .preloader--done .preloader__text--fail a {
    color: rgb(31, 98, 224);
  .preloader--done code {
    white-space: nowrap;
    padding: 2px 5px;
    margin: 0px 2px;
    font-size: 0.8rem;
    background-color: rgb(24, 27, 31);
    color: rgb(204, 204, 220);
    border: 1px solid rgba(204, 204, 220, 0.2);
    border-radius: 4px;
  .preloader__error-list li {
    margin-bottom: 8px;
  [ng\:cloak],
  [ng-cloak],
  .ng-cloak {
    display: none !important;
</style>
<div class="preloader">
  <div class="preloader__enter">
    <div class="preloader__bounce">
      <div class="preloader__logo" aria-live="polite" role="status" aria-label="Loading Grafana"></div>
    </div>
  </div>
  <div class="preloader__text preloader__text--fail">
    <main>
      <h1>If you're seeing this Grafana has failed to load its application files</h1>
      <ol class="preloader__error-list">
        <li>This could be caused by your reverse proxy settings.</li>
        <li>If you host grafana under a subpath make sure your <code>grafana.ini</code> <code>root_url</code> setting
          includes subpath. If not using a reverse proxy make sure to set <code>serve_from_sub_path</code> to true.</li>
        <li>If you have a local dev build make sure you build frontend using: <code>yarn start</code>, or
          <code>yarn build</code>.</li>
        <li>Sometimes restarting <code>grafana-server</code> can help.</li>
        <li>Check if you are using a non-supported browser. For more information, refer to the list of
          <a href="https://grafana.com/docs/grafana/latest/installation/requirements/#supported-web-browsers">
            supported browsers </a
          >.</li>
      </ol>
    </main>
  </div>
  <script nonce="">
    function checkBrowserCompatibility() {
      var isIE = navigator.userAgent.indexOf('MSIE') > -1;
      var isEdge = navigator.userAgent.indexOf('Edge/') > -1 || navigator.userAgent.indexOf('Edg/') > -1;
      var isFirefox = navigator.userAgent.toLowerCase().indexOf('firefox') > -1;
      var isChrome = /Chrome/.test(navigator.userAgent) && /Google Inc/.test(navigator.vendor);
      var isEdgeVersion = /Edge\/([0-9.]+)/.exec(navigator.userAgent);
      if (isIE && parseFloat(/Trident\/([0-9.]+)/.exec(navigator.userAgent)[1]) <= 7) {
        return false;
      } else if (
        isEdge &&
        ((isEdgeVersion && parseFloat(isEdgeVersion[1]) <= 16) ||
          parseFloat(/Edg\/([0-9.]+)/.exec(navigator.userAgent)[1]) <= 16)
        return false;
      } else if (isFirefox && parseFloat(/Firefox\/([0-9.]+)/.exec(navigator.userAgent)[1]) <= 64) {
        return false;
      } else if (isChrome && parseFloat(/Chrome\/([0-9.]+)/.exec(navigator.userAgent)[1]) <= 54) {
        return false;
      return true;
    if (!checkBrowserCompatibility()) {
      alert('Your browser is not fully supported, please try newer version.');
  </script>
</div>
<div id="reactRoot"></div>
<script nonce="">
  window.grafanaBootData = {
    user: {"isSignedIn":false,"id":0,"uid":"","login":"","email":"","name":"","theme":"dark","lightTheme":false,"orgCount":1,"orgId":0,"orgName":"","orgRole":"","isGrafanaAdmin":false,"gravatarUrl":"","timezone":"browser","weekStart":"browser","locale":"en-US","language":"en-US","helpFlags1":0,"hasEditPermissionInFolders":false,"authenticatedBy":"","permissions":{"folders:read":true},"analytics":{"identifier":"@http://localhost:3000/"}},
    settings: {"defaultDatasource":"-- Grafana --","datasources":{"-- Dashboard --":{"type":"datasource","name":"-- Dashboard --","meta":{"id":"dashboard","type":"datasource","name":"-- Dashboard --","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Uses the result set from another panel in the same dashboard","links":null,"logos":{"small":"public/app/plugins/datasource/dashboard/img/icn-reusequeries.svg","large":"public/app/plugins/datasource/dashboard/img/icn-reusequeries.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"dependencies":{"grafanaDependency":"","grafanaVersion":"*","plugins":[],"extensions":{"exposedComponents":[]}},"includes":null,"category":"","preload":false,"backend":false,"routes":null,"skipDataQuery":false,"autoEnabled":false,"extensions":{"addedLinks":[],"addedComponents":[],"exposedComponents":[],"extensionPoints":[]},"annotations":false,"metrics":true,"alerting":false,"explore":false,"tables":false,"logs":false,"tracing":false,"builtIn":true,"streaming":false,"signature":"internal","module":"core:plugin/dashboard","baseUrl":"public/app/plugins/datasource/dashboard","angular":{"detected":false,"hideDeprecation":false},"multiValueFilterOperators":false,"loadingStrategy":""},"isDefault":false,"preload":false,"jsonData":{},"readOnly":false,"cachingConfig":{"enabled":false,"TTLMs":0}},"-- Grafana --":{"id":-1,"uid":"grafana","type":"datasource","name":"-- Grafana --","meta":{"id":"grafana","type":"datasource","name":"-- Grafana --","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"A built-in data source that generates random walk data and can poll the Testdata data source. This helps you test visualizations and run experiments.","links":null,"logos":{"small":"public/app/plugins/datasource/grafana/img/icn-grafanadb.svg","large":"public/app/plugins/datasource/grafana/img/icn-grafanadb.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"dependencies":{"grafanaDependency":"","grafanaVersion":"*","plugins":[],"extensions":{"exposedComponents":[]}},"includes":null,"category":"","preload":false,"backend":true,"routes":null,"skipDataQuery":false,"autoEnabled":false,"extensions":{"addedLinks":[],"addedComponents":[],"exposedComponents":[],"extensionPoints":[]},"annotations":true,"metrics":true,"alerting":false,"explore":false,"tables":false,"logs":false,"tracing":false,"builtIn":true,"streaming":false,"signature":"internal","module":"core:plugin/grafana","baseUrl":"public/app/plugins/datasource/grafana","angular":{"detected":false,"hideDeprecation":false},"multiValueFilterOperators":false,"loadingStrategy":""},"isDefault":false,"preload":false,"jsonData":{},"readOnly":false,"cachingConfig":{"enabled":false,"TTLMs":0}},"-- Mixed --":{"type":"datasource","name":"-- Mixed --","meta":{"id":"mixed","type":"datasource","name":"-- Mixed --","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Lets you query multiple data sources in the same panel.","links":null,"logos":{"small":"public/app/plugins/datasource/mixed/img/icn-mixeddatasources.svg","large":"public/app/plugins/datasource/mixed/img/icn-mixeddatasources.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"dependencies":{"grafanaDependency":"","grafanaVersion":"*","plugins":[],"extensions":{"exposedComponents":[]}},"includes":null,"category":"","preload":false,"backend":false,"routes":null,"skipDataQuery":false,"autoEnabled":false,"extensions":{"addedLinks":[],"addedComponents":[],"exposedComponents":[],"extensionPoints":[]},"annotations":false,"metrics":true,"alerting":false,"explore":false,"tables":false,"logs":false,"tracing":false,"queryOptions":{"minInterval":true},"builtIn":true,"mixed":true,"streaming":false,"signature":"internal","module":"core:plugin/mixed","baseUrl":"public/app/plugins/datasource/mixed","angular":{"detected":false,"hideDeprecation":false},"multiValueFilterOperators":false,"loadingStrategy":""},"isDefault":false,"preload":false,"jsonData":{},"readOnly":false,"cachingConfig":{"enabled":false,"TTLMs":0}}},"minRefreshInterval":"5s","panels":{"alertlist":{"id":"alertlist","name":"Alert list","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Shows list of alerts and their current status","links":null,"logos":{"small":"public/app/plugins/panel/alertlist/img/icn-singlestat-panel.svg","large":"public/app/plugins/panel/alertlist/img/icn-singlestat-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":15,"skipDataQuery":true,"state":"","baseUrl":"public/app/plugins/panel/alertlist","signature":"internal","module":"core:plugin/alertlist","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"annolist":{"id":"annolist","name":"Annotations list","aliasIds":["ryantxu-annolist-panel"],"info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"List annotations","links":null,"logos":{"small":"public/app/plugins/panel/annolist/img/icn-annolist-panel.svg","large":"public/app/plugins/panel/annolist/img/icn-annolist-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":true,"state":"","baseUrl":"public/app/plugins/panel/annolist","signature":"internal","module":"core:plugin/annolist","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"barchart":{"id":"barchart","name":"Bar chart","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Categorical charts with group support","links":null,"logos":{"small":"public/app/plugins/panel/barchart/img/barchart.svg","large":"public/app/plugins/panel/barchart/img/barchart.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":2,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/barchart","signature":"internal","module":"core:plugin/barchart","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"bargauge":{"id":"bargauge","name":"Bar gauge","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Horizontal and vertical gauges","links":null,"logos":{"small":"public/app/plugins/panel/bargauge/img/icon_bar_gauge.svg","large":"public/app/plugins/panel/bargauge/img/icon_bar_gauge.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":5,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/bargauge","signature":"internal","module":"core:plugin/bargauge","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"candlestick":{"id":"candlestick","name":"Candlestick","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Graphical representation of price movements of a security, derivative, or currency.","links":null,"logos":{"small":"public/app/plugins/panel/candlestick/img/candlestick.svg","large":"public/app/plugins/panel/candlestick/img/candlestick.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":["financial","price","currency","k-line"]},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/candlestick","signature":"internal","module":"core:plugin/candlestick","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"canvas":{"id":"canvas","name":"Canvas","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Explicit element placement","links":null,"logos":{"small":"public/app/plugins/panel/canvas/img/icn-canvas.svg","large":"public/app/plugins/panel/canvas/img/icn-canvas.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/canvas","signature":"internal","module":"core:plugin/canvas","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"dashlist":{"id":"dashlist","name":"Dashboard list","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"List of dynamic links to other dashboards","links":null,"logos":{"small":"public/app/plugins/panel/dashlist/img/icn-dashlist-panel.svg","large":"public/app/plugins/panel/dashlist/img/icn-dashlist-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":16,"skipDataQuery":true,"state":"","baseUrl":"public/app/plugins/panel/dashlist","signature":"internal","module":"core:plugin/dashlist","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"flamegraph":{"id":"flamegraph","name":"Flame Graph","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"","links":null,"logos":{"small":"public/app/plugins/panel/flamegraph/img/icn-flamegraph.svg","large":"public/app/plugins/panel/flamegraph/img/icn-flamegraph.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/flamegraph","signature":"internal","module":"core:plugin/flamegraph","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"gauge":{"id":"gauge","name":"Gauge","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Standard gauge visualization","links":null,"logos":{"small":"public/app/plugins/panel/gauge/img/icon_gauge.svg","large":"public/app/plugins/panel/gauge/img/icon_gauge.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":4,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/gauge","signature":"internal","module":"core:plugin/gauge","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"geomap":{"id":"geomap","name":"Geomap","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Geomap panel","links":null,"logos":{"small":"public/app/plugins/panel/geomap/img/icn-geomap.svg","large":"public/app/plugins/panel/geomap/img/icn-geomap.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/geomap","signature":"internal","module":"core:plugin/geomap","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"gettingstarted":{"id":"gettingstarted","name":"Getting Started","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"","links":null,"logos":{"small":"public/app/plugins/panel/gettingstarted/img/icn-dashlist-panel.svg","large":"public/app/plugins/panel/gettingstarted/img/icn-dashlist-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":true,"sort":100,"skipDataQuery":true,"state":"","baseUrl":"public/app/plugins/panel/gettingstarted","signature":"internal","module":"core:plugin/gettingstarted","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"graph":{"id":"graph","name":"Graph (old)","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"The old default graph panel","links":null,"logos":{"small":"public/app/plugins/panel/graph/img/icn-graph-panel.svg","large":"public/app/plugins/panel/graph/img/icn-graph-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":13,"skipDataQuery":false,"state":"deprecated","baseUrl":"public/app/plugins/panel/graph","signature":"internal","module":"core:plugin/graph","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"heatmap":{"id":"heatmap","name":"Heatmap","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Like a histogram over time","links":null,"logos":{"small":"public/app/plugins/panel/heatmap/img/icn-heatmap-panel.svg","large":"public/app/plugins/panel/heatmap/img/icn-heatmap-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":10,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/heatmap","signature":"internal","module":"core:plugin/heatmap","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"histogram":{"id":"histogram","name":"Histogram","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Distribution of values presented as a bar chart.","links":null,"logos":{"small":"public/app/plugins/panel/histogram/img/histogram.svg","large":"public/app/plugins/panel/histogram/img/histogram.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":["distribution","bar chart","frequency","proportional"]},"hideFromList":false,"sort":12,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/histogram","signature":"internal","module":"core:plugin/histogram","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"logs":{"id":"logs","name":"Logs","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"","links":null,"logos":{"small":"public/app/plugins/panel/logs/img/icn-logs-panel.svg","large":"public/app/plugins/panel/logs/img/icn-logs-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/logs","signature":"internal","module":"core:plugin/logs","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"news":{"id":"news","name":"News","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"RSS feed reader","links":null,"logos":{"small":"public/app/plugins/panel/news/img/news.svg","large":"public/app/plugins/panel/news/img/news.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":17,"skipDataQuery":true,"state":"beta","baseUrl":"public/app/plugins/panel/news","signature":"internal","module":"core:plugin/news","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"nodeGraph":{"id":"nodeGraph","name":"Node Graph","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"","links":null,"logos":{"small":"public/app/plugins/panel/nodeGraph/img/icn-node-graph.svg","large":"public/app/plugins/panel/nodeGraph/img/icn-node-graph.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/nodeGraph","signature":"internal","module":"core:plugin/nodeGraph","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"piechart":{"id":"piechart","name":"Pie chart","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"The new core pie chart visualization","links":null,"logos":{"small":"public/app/plugins/panel/piechart/img/icon_piechart.svg","large":"public/app/plugins/panel/piechart/img/icon_piechart.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":8,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/piechart","signature":"internal","module":"core:plugin/piechart","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"stat":{"id":"stat","name":"Stat","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Big stat values \u0026 sparklines","links":null,"logos":{"small":"public/app/plugins/panel/stat/img/icn-singlestat-panel.svg","large":"public/app/plugins/panel/stat/img/icn-singlestat-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":3,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/stat","signature":"internal","module":"core:plugin/stat","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"state-timeline":{"id":"state-timeline","name":"State timeline","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"State changes and durations","links":null,"logos":{"small":"public/app/plugins/panel/state-timeline/img/timeline.svg","large":"public/app/plugins/panel/state-timeline/img/timeline.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":9,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/state-timeline","signature":"internal","module":"core:plugin/state-timeline","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"status-history":{"id":"status-history","name":"Status history","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Periodic status history","links":null,"logos":{"small":"public/app/plugins/panel/status-history/img/status.svg","large":"public/app/plugins/panel/status-history/img/status.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":11,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/status-history","signature":"internal","module":"core:plugin/status-history","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"table":{"id":"table","name":"Table","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Supports many column styles","links":null,"logos":{"small":"public/app/plugins/panel/table/img/icn-table-panel.svg","large":"public/app/plugins/panel/table/img/icn-table-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":6,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/table","signature":"internal","module":"core:plugin/table","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"table-old":{"id":"table-old","name":"Table (old)","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Table Panel for Grafana","links":null,"logos":{"small":"public/app/plugins/panel/table-old/img/icn-table-panel.svg","large":"public/app/plugins/panel/table-old/img/icn-table-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"deprecated","baseUrl":"public/app/plugins/panel/table-old","signature":"internal","module":"core:plugin/table-old","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"text":{"id":"text","name":"Text","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Supports markdown and html content","links":null,"logos":{"small":"public/app/plugins/panel/text/img/icn-text-panel.svg","large":"public/app/plugins/panel/text/img/icn-text-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":14,"skipDataQuery":true,"state":"","baseUrl":"public/app/plugins/panel/text","signature":"internal","module":"core:plugin/text","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"timeseries":{"id":"timeseries","name":"Time series","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Time based line, area and bar charts","links":null,"logos":{"small":"public/app/plugins/panel/timeseries/img/icn-timeseries-panel.svg","large":"public/app/plugins/panel/timeseries/img/icn-timeseries-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":1,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/timeseries","signature":"internal","module":"core:plugin/timeseries","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"traces":{"id":"traces","name":"Traces","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"","links":null,"logos":{"small":"public/app/plugins/panel/traces/img/traces-panel.svg","large":"public/app/plugins/panel/traces/img/traces-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/traces","signature":"internal","module":"core:plugin/traces","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"trend":{"id":"trend","name":"Trend","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Like timeseries, but when x != time","links":null,"logos":{"small":"public/app/plugins/panel/trend/img/trend.svg","large":"public/app/plugins/panel/trend/img/trend.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"beta","baseUrl":"public/app/plugins/panel/trend","signature":"internal","module":"core:plugin/trend","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"welcome":{"id":"welcome","name":"Welcome","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"","links":null,"logos":{"small":"public/app/plugins/panel/welcome/img/icn-dashlist-panel.svg","large":"public/app/plugins/panel/welcome/img/icn-dashlist-panel.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":null},"hideFromList":true,"sort":100,"skipDataQuery":true,"state":"","baseUrl":"public/app/plugins/panel/welcome","signature":"internal","module":"core:plugin/welcome","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"},"xychart":{"id":"xychart","name":"XY Chart","info":{"author":{"name":"Grafana Labs","url":"https://grafana.com"},"description":"Supports arbitrary X vs Y in a graph to visualize the relationship between two variables.","links":null,"logos":{"small":"public/app/plugins/panel/xychart/img/icn-xychart.svg","large":"public/app/plugins/panel/xychart/img/icn-xychart.svg"},"build":{},"screenshots":null,"version":"","updated":"","keywords":["scatter","plot"]},"hideFromList":false,"sort":100,"skipDataQuery":false,"state":"","baseUrl":"public/app/plugins/panel/xychart","signature":"internal","module":"core:plugin/xychart","angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script"}},"apps":{"grafana-lokiexplore-app":{"id":"grafana-lokiexplore-app","path":"public/plugins/grafana-lokiexplore-app/module.js","version":"1.0.8","preload":true,"angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script","extensions":{"addedLinks":[{"targets":["grafana/dashboard/panel/menu","grafana/explore/toolbar/action"],"title":"Open in Grafana Logs Drilldown","description":"Open current query in the Grafana Logs Drilldown view"}],"addedComponents":[],"exposedComponents":[{"id":"grafana-lokiexplore-app/open-in-explore-logs-button/v1","title":"Open in Explore Logs button","description":"A button that opens a logs view in the Explore Logs app."}],"extensionPoints":[{"id":"grafana-lokiexplore-app/investigation/v1","title":"","description":""},{"id":"grafana-lokiexplore-app/toolbar-open-related/v1","title":"Open related signals like metrics/traces/profiles","description":""}]},"dependencies":{"grafanaDependency":"\u003e=11.3.0","grafanaVersion":"*","plugins":[],"extensions":{"exposedComponents":["grafana-adaptivelogs-app/temporary-exemptions/v1"]}}},"grafana-pyroscope-app":{"id":"grafana-pyroscope-app","path":"public/plugins/grafana-pyroscope-app/module.js","version":"1.2.0","preload":true,"angular":{"detected":false,"hideDeprecation":false},"loadingStrategy":"script","extensions":{"addedLinks":[{"targets":["grafana/explore/toolbar/action","grafana/traceview/details"],"title":"Open in Grafana Profiles Drilldown","description":"Try our new queryless experience for profiles"}],"addedComponents":[],"exposedComponents":[],"extensionPoints":[{"id":"grafana-pyroscope-app/investigation/v1","title":"","description":""}]},"dependencies":{"grafanaDependency":"\u003e=11.5.0","grafanaVersion":"*","plugins":[],"extensions":{"exposedComponents":[]}}}},"appUrl":"http://localhost:3000/","appSubUrl":"","allowOrgCreate":false,"authProxyEnabled":false,"ldapEnabled":false,"jwtHeaderName":"","jwtUrlLogin":false,"liveEnabled":true,"autoAssignOrg":true,"verifyEmailEnabled":false,"sigV4AuthEnabled":false,"azureAuthEnabled":false,"rbacEnabled":true,"exploreEnabled":true,"helpEnabled":true,"profileEnabled":true,"newsFeedEnabled":true,"queryHistoryEnabled":true,"googleAnalyticsId":"","googleAnalytics4Id":"","GoogleAnalytics4SendManualPageViews":false,"rudderstackWriteKey":"","rudderstackDataPlaneUrl":"","rudderstackSdkUrl":"","rudderstackConfigUrl":"","rudderstackIntegrationsUrl":"","analyticsConsoleReporting":false,"feedbackLinksEnabled":true,"applicationInsightsConnectionString":"","applicationInsightsEndpointUrl":"","disableLoginForm":false,"disableUserSignUp":true,"loginHint":"","passwordHint":"","externalUserMngInfo":"","externalUserMngLinkUrl":"","externalUserMngLinkName":"","viewersCanEdit":false,"angularSupportEnabled":false,"editorsCanAdmin":false,"disableSanitizeHtml":false,"trustedTypesDefaultPolicyEnabled":false,"cspReportOnlyEnabled":false,"enableFrontendSandboxForPlugins":[""],"exploreDefaultTimeOffset":"1h","auth":{"AuthProxyEnableLoginToken":false,"OAuthSkipOrgRoleUpdateSync":false,"SAMLSkipOrgRoleSync":false,"LDAPSkipOrgRoleSync":false,"GoogleSkipOrgRoleSync":false,"GenericOAuthSkipOrgRoleSync":false,"JWTAuthSkipOrgRoleSync":false,"GrafanaComSkipOrgRoleSync":false,"AzureADSkipOrgRoleSync":false,"GithubSkipOrgRoleSync":false,"GitLabSkipOrgRoleSync":false,"OktaSkipOrgRoleSync":false,"disableLogin":false,"basicAuthStrongPasswordPolicy":false,"passwordlessEnabled":false},"buildInfo":{"hideVersion":false,"version":"11.5.2","versionString":"Grafana v11.5.2 (598e0338d5)","commit":"598e0338d5374d6bc404b02a58094132c5eeceb8","commitShort":"598e0338d5","buildstamp":1741671848,"edition":"Open Source","latestVersion":"11.5.2","hasUpdate":false,"env":"production"},"licenseInfo":{"expiry":0,"stateInfo":"","licenseUrl":"https://grafana.com/oss/grafana?utm_source=grafana_footer","edition":"Open Source","enabledFeatures":{}},"featureToggles":{"accessActionSets":true,"accessControlOnCall":true,"addFieldFromCalculationStatFunctions":true,"alertingApiServer":true,"alertingInsights":true,"alertingNoDataErrorExecution":true,"alertingSimplifiedRouting":true,"alertingUIOptimizeReducer":true,"angularDeprecationUI":true,"annotationPermissionUpdate":true,"awsAsyncQueryCaching":true,"azureMonitorEnableUserAuth":true,"cloudWatchCrossAccountQuerying":true,"cloudWatchNewLabelParsing":true,"cloudWatchRoundUpEndTime":true,"correlations":true,"dashboardScene":true,"dashboardSceneForViewers":true,"dashboardSceneSolo":true,"dashgpt":true,"dataplaneFrontendFallback":true,"exploreMetrics":true,"formatString":true,"groupToNestedTableTransformation":true,"influxdbBackendMigration":true,"kubernetesPlaylists":true,"logRowsPopoverMenu":true,"logsContextDatasourceUi":true,"logsExploreTableVisualisation":true,"logsInfiniteScrolling":true,"lokiLabelNamesQueryApi":true,"lokiQueryHints":true,"lokiQuerySplitting":true,"lokiStructuredMetadata":true,"managedPluginsInstall":true,"nestedFolders":true,"newDashboardSharingComponent":true,"newFiltersUI":true,"newPDFRendering":true,"onPremToCloudMigrations":true,"openSearchBackendFlowEnabled":true,"panelMonitoring":true,"pinNavItems":true,"preinstallAutoUpdate":true,"promQLScope":true,"prometheusAzureOverrideAudience":true,"publicDashboardsScene":true,"recordedQueriesMulti":true,"recoveryThreshold":true,"reportingUseRawTimeRange":true,"ssoSettingsApi":true,"tlsMemcached":true,"topnav":true,"transformationsRedesign":true,"transformationsVariableSupport":true,"unifiedRequestLog":true,"useSessionStorageForRedirection":true,"userStorageAPI":true,"zipkinBackendMigration":true},"anonymousEnabled":false,"anonymousDeviceLimit":0,"rendererAvailable":false,"rendererVersion":"","rendererDefaultImageWidth":1000,"rendererDefaultImageHeight":500,"rendererDefaultImageScale":1,"secretsManagerPluginEnabled":false,"http2Enabled":false,"grafanaJavascriptAgent":{"enabled":false,"customEndpoint":"/log-grafana-javascript-agent","allInstrumentationEnabeld":false,"errorInstrumentalizationEnabled":true,"consoleInstrumentalizationEnabled":false,"webVitalsInstrumentalizationEnabled":false,"tracingInstrumentalizationEnabled":false,"internalLoggerLevel":0,"apiKey":""},"pluginCatalogURL":"https://grafana.com/grafana/plugins/","pluginAdminEnabled":true,"pluginAdminExternalManageEnabled":false,"pluginCatalogHiddenPlugins":[],"pluginCatalogManagedPlugins":[],"pluginCatalogPreinstalledPlugins":[{"id":"grafana-lokiexplore-app","version":""},{"id":"grafana-pyroscope-app","version":""}],"expressionsEnabled":true,"awsAllowedAuthProviders":["default","keys","credentials"],"awsAssumeRoleEnabled":true,"supportBundlesEnabled":true,"snapshotEnabled":true,"secureSocksDSProxyEnabled":false,"reportingStaticContext":{},"azure":{"cloud":"AzureCloud"},"defaultDatasourceManageAlertsUiToggle":true,"caching":{"enabled":true},"recordedQueries":{"enabled":true},"reporting":{"enabled":true},"analytics":{"enabled":true},"unifiedAlertingEnabled":true,"unifiedAlerting":{"minInterval":"10s","alertStateHistoryBackend":"annotations"},"oauth":{},"samlEnabled":false,"samlName":"","tokenExpirationDayLimit":-1,"sharedWithMeFolderUID":"sharedwithme","rootFolderUID":"general","passwordlessEnabled":"","geomapDisableCustomBaseLayer":false,"publicDashboardAccessToken":"","publicDashboardsEnabled":true,"cloudMigrationIsTarget":false,"cloudMigrationFeedbackURL":"https://docs.google.com/forms/d/e/1FAIpQLSeEE33vhbSpR8A8S1A1ocZ1ByVRRwiRl1GZr2FSrEer_tSa8w/viewform?usp=sf_link","cloudMigrationPollIntervalMs":2000,"dateFormats":{"fullDate":"YYYY-MM-DD HH:mm:ss","useBrowserLocale":false,"interval":{"millisecond":"HH:mm:ss.SSS","second":"HH:mm:ss","minute":"HH:mm","hour":"MM/DD HH:mm","day":"MM/DD","month":"YYYY-MM","year":"YYYY"},"defaultTimezone":"browser","defaultWeekStart":"browser"},"namespace":"org-0","sqlConnectionLimits":{"maxOpenConns":100,"maxIdleConns":100,"connMaxLifetime":14400},"localFileSystemAvailable":true,"listScopesEndpoint":"","listDashboardScopesEndpoint":""},
    navTree: [{"id":"home","text":"Home","icon":"home-alt","url":"/login","sortWeight":-2000},{"id":"help","text":"Help","subTitle":"Grafana v11.5.2 (598e0338d5)","icon":"question-circle","url":"#","sortWeight":-100}],
    assets: {"jsFiles":[{"filePath":"public/build/runtime.c32e149e6891502b523d.js","integrity":"sha256-UvzEOUM/1G0WVjzW3buZcUwgPwaDWdL13rw6v6JVtLo= sha384-oYh2elzHM1Q2CK6SJ4bZ//J8HUPWIJTXvHgYBjZKYg7qPkHh4U+EAO3ym07060l4 sha512-oieoIn6zjMBMf0DgmBaXpG0Pvr1Lnjrx2IFWxxq0gfNFbYCN07s32dVycFI+ZPST85lH1nYeuO2+pdettmhmzQ=="},{"filePath":"public/build/6029.0549a3fcb50e73c4b256.js","integrity":"sha256-z40zPoeFjJLRgwDGeCC0rqEAPnaHNnzfrgSXI5H/5Rs= sha384-Otd1wLPciZ+tOJke2wbZQse4pmXNMdivu6XYXws1Z9H7Iy5TXpsS6Ja0Ke6p5Ti0 sha512-LFZ8zOE5Cke3SRGx5a2NMChf1LtQ1oTins3n4XA0/w9Wpn7cBzJpSGzuLUtN3pAOtDsZmQp0+CPdOdS/v/E44A=="},{"filePath":"public/build/3196.0d4b1a0bf9502490c781.js","integrity":"sha256-oBdxzuceWwYIzYOn0fSQO6urxICj/Yn6pIn7HxeYqJo= sha384-ZLiEeLINQ4L9v8smigr2SYq0EYSk/C3YvbkuoJx7jN/YIiiSqyoE/AP0KfnmpmSK sha512-4qYBHCaKlHXg/3QuQThsAkM8UxIklO00WskW9Cb9AvLGoouhRF1XV0tglS48qipdyhayPvRid9hUUUG2HrVvmw=="},{"filePath":"public/build/9890.2f086d4a8fdbd47b8d24.js","integrity":"sha256-CgJ7dvG28rQZPYfRb+wNxvnPa1X760xzfsysS83nqOo= sha384-4mz3vSPTaF/FNAC6zrPjgdjcG/Ea5p87CF4sqVpy3vhozXtHjAXKR4LZDw6MZP+y sha512-2G8yXs230mZvhlqXl8Rfq41jP6W1Af0dubZZPFZimh62QfoyTB1JLtKPrLcvOYWnaCH49hCG2aZobMH8Pu5LtA=="},{"filePath":"public/build/7836.125f6c2757ee541f83cc.js","integrity":"sha256-QUoMg0WKFmx08kcOASK/g9ZR458GciRQ6tp0YtVlWr0= sha384-yiaOn2Xw3ZC+qweWBhb5X+RHn/AxeolXuWxl4Q0Vfql8F+f3hcRa7gJC1ykpozMq sha512-9heB7bwqsIObUPEwidETlEajaf8DnH85jdr1+X7JrgqwQKvx1aLh8PUgfUXRMv0wKGYpMbD0KoD66/PUKW9riA=="},{"filePath":"public/build/2041.db61d9e0bd49170a31de.js","integrity":"sha256-ASE09DDqnVF5JGWVTEQFcI8j5yqYMGw5SR1GCHfMsio= sha384-U5Gg1xWSS3ETyeWc22lXu0G94pwpLznPCb2gjng1VyAyEDBXsuZOB29lja91lqNB sha512-u0RBCme+RmMTy0sunN72p2hX6xE6G9Tc3Gosu0GVrPF+7LdrgU0wkxwl3EfsueUrOnrov1EJ+NXdmYiSE2dMaw=="},{"filePath":"public/build/355.99c61a8a485bbdf597fd.js","integrity":"sha256-42cCN08SMOhVttSRlEIqUcAgaZhracdvSpA3Hymx2fA= sha384-n5GXF2WOUQUqjOV3tfxtW0lIy3AqmSQobIcymOoSMYDsttqsBj0AsKsLcoPyC6Ke sha512-cWMH3FhDthj2QU0Ggzpua0OD0u0GLNcgBPrDYgH0AAfORVCBGaHKUiNhCR3d/jb4IGBBdHJnDUI3AbDgNO823g=="},{"filePath":"public/build/app.6c1b6fd0007a0fd460b5.js","integrity":"sha256-fiGrDgP6twTBln1IlTy/3ctPYHjFe48C4UrPJUVBFvs= sha384-aTAYfDRUBSoVIJOwO15ckAvZu1mIABBc1TN4mCEL4hy2AnfUmDIeZliAS6VEa5d5 sha512-hYlbNsAsV633Wxw7eS+DG+Ick0ylRTj4nJ0TIqOOP7egbpMQLj9i3WKEancM4ms0g5Qz027SNbPYXi+lejau5w=="}],"cssFiles":[{"filePath":"public/build/grafana.app.ad2ed81beeec71531a35.css","integrity":"sha256-aV6eaOuCTJhnuh5HhTOMf8MHhpLu1nhEYCTeaOIR5Og= sha384-NRSL3KOuNCS0jEj+YeO8T5wD49Fr1FbNUn9iGXXQpdRSc1eZf36c2D6B4sfAK3d+ sha512-8EOqmUQlsbuVzDsXAcCtQPq7egRjRI+aUHrwnrEbLrVJam9w4awhGG5bH2XMDpBd80/YNJGSe2l0uhWZJJT6lg=="}],"dark":"public/build/grafana.dark.23c5425b7a9e1580d499.css","light":"public/build/grafana.light.53ec5bfb490b0419985b.css","swagger":[{"filePath":"public/build/runtime.c32e149e6891502b523d.js","integrity":"sha256-UvzEOUM/1G0WVjzW3buZcUwgPwaDWdL13rw6v6JVtLo= sha384-oYh2elzHM1Q2CK6SJ4bZ//J8HUPWIJTXvHgYBjZKYg7qPkHh4U+EAO3ym07060l4 sha512-oieoIn6zjMBMf0DgmBaXpG0Pvr1Lnjrx2IFWxxq0gfNFbYCN07s32dVycFI+ZPST85lH1nYeuO2+pdettmhmzQ=="},{"filePath":"public/build/6029.0549a3fcb50e73c4b256.js","integrity":"sha256-z40zPoeFjJLRgwDGeCC0rqEAPnaHNnzfrgSXI5H/5Rs= sha384-Otd1wLPciZ+tOJke2wbZQse4pmXNMdivu6XYXws1Z9H7Iy5TXpsS6Ja0Ke6p5Ti0 sha512-LFZ8zOE5Cke3SRGx5a2NMChf1LtQ1oTins3n4XA0/w9Wpn7cBzJpSGzuLUtN3pAOtDsZmQp0+CPdOdS/v/E44A=="},{"filePath":"public/build/3196.0d4b1a0bf9502490c781.js","integrity":"sha256-oBdxzuceWwYIzYOn0fSQO6urxICj/Yn6pIn7HxeYqJo= sha384-ZLiEeLINQ4L9v8smigr2SYq0EYSk/C3YvbkuoJx7jN/YIiiSqyoE/AP0KfnmpmSK sha512-4qYBHCaKlHXg/3QuQThsAkM8UxIklO00WskW9Cb9AvLGoouhRF1XV0tglS48qipdyhayPvRid9hUUUG2HrVvmw=="},{"filePath":"public/build/5853.9a9de1ac643be29b9631.js","integrity":"sha256-HUkG+jbcUdnjpfKa1JmWPVuzLRkqcE7hY65wqPYSz6c= sha384-lTovThVpjKu/tqj4xWRO9apZgL+wgJHWxDV9f0pFph2Jiw107I+EDnL1+kDzvAGS sha512-6E+KkPct5Z9RqVMO1rY7+MZzznftnut/Q7FOFutP4+fOX+1lNZ2rAQ+87gz7skB3lhCVUK+gdrd7nh4jvx37KQ=="},{"filePath":"public/build/7836.125f6c2757ee541f83cc.js","integrity":"sha256-QUoMg0WKFmx08kcOASK/g9ZR458GciRQ6tp0YtVlWr0= sha384-yiaOn2Xw3ZC+qweWBhb5X+RHn/AxeolXuWxl4Q0Vfql8F+f3hcRa7gJC1ykpozMq sha512-9heB7bwqsIObUPEwidETlEajaf8DnH85jdr1+X7JrgqwQKvx1aLh8PUgfUXRMv0wKGYpMbD0KoD66/PUKW9riA=="},{"filePath":"public/build/swagger.57f2bc49f30d0342b707.js","integrity":"sha256-pW1cZ4LkU/ADZmZfM4crPB+keOO0R6TD9V5JbP3gLE0= sha384-Juox2Be0PrXb1RwYih5ygN3R/BJUETLLSDobhLy3T8MTA+Qlsx0AvEW23Z3MM26g sha512-eKnCk4ZA2xKUKtut6choovNLNnYxzxJSbzv8GDRcf64XEwwNXgcoDW6B9Az9jYEsmKdkdZ6VAm+i/kniI2glCA=="}],"swaggerCssFiles":[{"filePath":"public/build/grafana.swagger.4ffa23b5aeeedb24a80a.css","integrity":"sha256-TPnkYhL685I2Tx2v9nj91T5N/S9JaF7IZdr4P5Gy1+o= sha384-K8hHvTK5GoUQc3bLXFJbPfQ6zg6h9fbSoSDGjDUZk6Xxea+RFYWCXWUnQkdk+ls+ sha512-MnCZC2zriiPdgI2Ou7FXekY41LfCVXLATpwki4pG3fd9sah7/KxO1mJ+uNAg/XFs8UKjzR2gTwDtUMGWvQ8lFg=="}]}
  if (window.grafanaBootData.user.theme === "system") {
    document.body.classList.remove("theme-system");
    var darkQuery = window.matchMedia("(prefers-color-scheme: dark)");
    var cssLink = document.createElement("link");
    cssLink.rel = 'stylesheet';
    if (darkQuery.matches) {
      document.body.classList.add("theme-dark");
      cssLink.href = window.grafanaBootData.assets.dark;
      window.grafanaBootData.user.lightTheme = false;
    } else {
      document.body.classList.add("theme-light");
      cssLink.href = window.grafanaBootData.assets.light;
      window.grafanaBootData.user.lightTheme = true;
    document.head.appendChild(cssLink);
  window.__grafana_load_failed = function() {
    var preloader = document.getElementsByClassName("preloader");
    if (preloader.length) {
      preloader[0].className = "preloader preloader--done";
  window.onload = function() {
    if (window.__grafana_app_bundle_loaded) {
      return;
    window.__grafana_load_failed();
</script>
  <script
  nonce=""
  src="public/build/runtime.c32e149e6891502b523d.js"
  type="text/javascript"
  defer
></script>
  <script
  nonce=""
  src="public/build/6029.0549a3fcb50e73c4b256.js"
  defer
></script>
  <script
  nonce=""
  src="public/build/3196.0d4b1a0bf9502490c781.js"
  defer
></script>
  <script
  nonce=""
  src="public/build/9890.2f086d4a8fdbd47b8d24.js"
  defer
></script>
  <script
  nonce=""
  src="public/build/7836.125f6c2757ee541f83cc.js"
  defer
></script>
  <script
  nonce=""
  src="public/build/2041.db61d9e0bd49170a31de.js"
  defer
></script>
  <script
  nonce=""
  src="public/build/355.99c61a8a485bbdf597fd.js"
  defer
></script>
  <script
  nonce=""
  src="public/build/app.6c1b6fd0007a0fd460b5.js"
  defer
></script>
<script nonce="">
  performance.mark('frontend_boot_js_done_time_seconds');
</script>
* Connection #0 to host localhost left intact
I would like know how to access the Web UI of garafana in my environment. ( I already checked the firewall service,and iptables)
  1. a-zA-Z ↩︎
