Hi, All
After opening Grafana addon GUI and trying to open plugin catalog on Grafana server message appears:
" This filter has been disabled because the Grafana server cannot access grafana.com "
I looked through everything I could find on this topic, but I didn’t find anything and couldn’t find in the Grafana documentation what this message means
Gtafana itself has access to the Internet and to gtafana.com .
Any fixup, advise, whatever to eliminate this trouble
Can you increase the verbosity of the Grafana server logs to debug
and note any errors. For printing to console, set the console logs to debug
as well?
what version are you running?
I’m running Grafana add-on version 7.5.2 for Home Assistant .
The problem appeared after restarting the HA server a month ago.
Log “info” attached below.
For “debug” level- I have no idea how to attach it in txt format, for pic format it’s too long…
I didn’t find any errors in it.
There are also no errors at the debug level.
On the firewall I see the allowed connection of the host with grafana.com (ip: 34.120.177.193) on port 443.
==== log INFO =====
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Add-on: Grafana
The open platform for beautiful analytics and monitoring
Add-on version: 7.5.2
You are running the latest version of this add-on.
System: Home Assistant OS 7.6 (amd64 / qemux86-64)
Home Assistant Core: 2022.4.7
Home Assistant Supervisor: 2022.04.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] grafana.sh: executing…
[cont-init.d] grafana.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[07:47:15] INFO: Starting Memcached…
[07:47:15] INFO: Starting Grafana…
[07:47:15] INFO: Setting GF_AUTH_ANONYMOUS_ENABLED to true
[07:47:15] INFO: Setting GF_AUTH_ANONYMOUS_ORG_NAME to Hamsterville
[07:47:15] INFO: Setting GF_AUTH_DISABLE_LOGIN_FORM to true
[07:47:16] INFO: Setting GF_AUTH_ANONYMOUS_ORG_ROLE to Viewer
[07:47:16] INFO: Setting GF_USERS_ALLOW_SIGN_UP to false
Grafana server is running with elevated privileges. This is not recommended
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Starting Grafana” version=8.4.4 commit=fcfb01faeb branch=HEAD compiled=2022-03-16T16:36:26+03:00
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=warn msg=“falling back to legacy setting of ‘min_interval_seconds’; please use the configuration option in the unified_alerting
section if Grafana 8 alerts are enabled.”
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_USERS_ALLOW_SIGN_UP=false”
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_DISABLE_LOGIN_FORM=true”
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_ANONYMOUS_ENABLED=true”
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_ANONYMOUS_ORG_NAME=Hamsterville”
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_ANONYMOUS_ORG_ROLE=Viewer”
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Path Data” path=/data
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Path Logs” path=/var/logs/grafana
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Path Provisioning” path=/usr/share/grafana/conf/provisioning
logger=settings t=2022-04-29T07:47:16.14+0300 lvl=info msg=“App mode production”
logger=sqlstore t=2022-04-29T07:47:16.14+0300 lvl=info msg=“Connecting to DB” dbtype=sqlite3
logger=migrator t=2022-04-29T07:47:16.15+0300 lvl=info msg=“Starting DB migrations”
logger=migrator t=2022-04-29T07:47:16.16+0300 lvl=info msg=“migrations completed” performed=0 skipped=381 duration=383.84µs
logger=plugin.manager t=2022-04-29T07:47:16.18+0300 lvl=info msg=“Plugin registered” pluginId=input
logger=plugin.manager t=2022-04-29T07:47:18.68+0300 lvl=info msg=“Plugin registered” pluginId=grafana-image-renderer
logger=query_data t=2022-04-29T07:47:18.68+0300 lvl=info msg=“Query Service initialization”
logger=live.push_http t=2022-04-29T07:47:18.69+0300 lvl=info msg=“Live Push Gateway initialization”
logger=http.server t=2022-04-29T07:47:18.75+0300 lvl=info msg=“HTTP Server Listen” address=[::]:3000 protocol=http subUrl=/api/hassio_ingress/I-8kne54LChWLV-O-VBOJoqFZHTkrK8Oor1i-Rwg70Y socket=
logger=ngalert t=2022-04-29T07:47:18.75+0300 lvl=info msg=“warming cache for startup”
logger=ngalert.multiorg.alertmanager t=2022-04-29T07:47:18.75+0300 lvl=info msg=“starting MultiOrg Alertmanager”
[07:47:19] INFO: Starting NGinx…
logger=plugin.grafana-image-renderer t=2022-04-29T07:47:19.31+0300 lvl=warn msg=“Plugin process is running with elevated privileges. This is not recommended”
==== log INFO =====
==== log INFO =====
[fix-attrs.d] done.
Add-on: Grafana
[cont-init.d] done.
[services.d] done.
==== Debus Log ====
[fix-attrs.d] done.
Add-on: Grafana
Log level is set to DEBUG
[cont-init.d] done.
[services.d] done.
[17:07:46] INFO: Starting Memcached…
[17:07:46] INFO: Starting Grafana…
[17:07:46] INFO: Setting GF_AUTH_ANONYMOUS_ENABLED to true
[17:07:46] INFO: Setting GF_AUTH_ANONYMOUS_ORG_NAME to Hamsterville
[17:07:46] INFO: Setting GF_AUTH_DISABLE_LOGIN_FORM to true
[17:07:46] INFO: Setting GF_AUTH_ANONYMOUS_ORG_ROLE to Viewer
[17:07:46] INFO: Setting GF_USERS_ALLOW_SIGN_UP to false
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Starting Grafana” version=8.4.4 commit=fcfb01faeb branch=HEAD compiled=2022-03-16T16:36:26+03:00
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=warn msg=“falling back to legacy setting of ‘min_interval_seconds’; please use the configuration option in the unified_alerting
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_USERS_ALLOW_SIGN_UP=false”
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_DISABLE_LOGIN_FORM=true”
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_ANONYMOUS_ENABLED=true”
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_ANONYMOUS_ORG_NAME=Hamsterville”
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Config overridden from Environment variable” var=“GF_AUTH_ANONYMOUS_ORG_ROLE=Viewer”
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Path Data” path=/data
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Path Logs” path=/var/logs/grafana
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Path Provisioning” path=/usr/share/grafana/conf/provisioning
logger=settings t=2022-04-30T17:07:46.82+0300 lvl=info msg=“App mode production”
logger=sqlstore t=2022-04-30T17:07:46.82+0300 lvl=info msg=“Connecting to DB” dbtype=sqlite3
logger=migrator t=2022-04-30T17:07:46.83+0300 lvl=info msg=“Starting DB migrations”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create migration_log table”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create user table”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“add unique index user.login”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“add unique index user.email”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index UQE_user_login - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index UQE_user_email - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Rename table user to user_v1 - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create user table v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index UQE_user_login - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index UQE_user_email - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“copy data_source v1 to v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Drop old table user_v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column help_flags1 to user table”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update user table charset”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add last_seen_at column to user”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add missing user data”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add is_disabled column to user”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add index user.login/user.email”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add is_service_account column to user”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create temp user table v1-7”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_email - v1-7”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_org_id - v1-7”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_code - v1-7”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_status - v1-7”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update temp_user table charset”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index IDX_temp_user_email - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index IDX_temp_user_org_id - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index IDX_temp_user_code - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index IDX_temp_user_status - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Rename table temp_user to temp_user_tmp_qwerty - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create temp_user v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_email - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_org_id - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_code - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_temp_user_status - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“copy temp_user v1 to v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop temp_user_tmp_qwerty”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Set created for temp users that will otherwise prematurely expire”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create star table”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“add unique index star.user_id_dashboard_id”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create org table v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index UQE_org_name - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create org_user table v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_org_user_org_id - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index UQE_org_user_org_id_user_id - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_org_user_user_id - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update org table charset”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update org_user table charset”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Migrate all Read Only Viewers to Viewers”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create dashboard table”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“add index dashboard.account_id”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“add unique index dashboard_account_id_slug”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create dashboard_tag table”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“add unique index dashboard_tag.dasboard_id_term”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop index UQE_dashboard_tag_dashboard_id_term - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Rename table dashboard to dashboard_v1 - v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create dashboard v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index IDX_dashboard_org_id - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“create index UQE_dashboard_org_id_slug - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“copy dashboard v1 to v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“drop table dashboard_v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“alter dashboard.data to mediumtext v1”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column updated_by in dashboard - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column created_by in dashboard - v2”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column gnetId in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add index for gnetId in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column plugin_id in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add index for plugin_id in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add index for dashboard_id in dashboard_tag”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update dashboard table charset”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update dashboard_tag table charset”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column folder_id in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column isFolder in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column has_acl in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Add column uid in dashboard”
logger=migrator t=2022-04-30T17:07:46.84+0300 lvl=dbug msg=“Skipping migration: Already executed” id=“Update uid column values in dashboard”
I am seeing the same issue
12 days… nothing, silence, without any advise or solution.
@allenrobberson and other who have the same problem - try to install plugin from catalog though config file. It`s not handy but it works to me.
