Dear Grafana community, can you please help.
- I changed http_port from 3000 to 8080.
2)After i started by cmd this command : C:\distr\grafana-6.2.0.windows-amd64\grafana-6.2.0\bin>grafana-server install
But i see next messages long time :
←[32mINFO←[0m[05-31|11:45:19] Initializing UserAuthTokenService ←[32mlogger←[0m=server
←[32mINFO←[0m[05-31|11:45:19] Initializing CleanUpService ←[32mlogger←[0m=server
←[32mINFO←[0m[05-31|11:45:19] Initializing NotificationService ←[32mlogger←[0m=server
←[32mINFO←[0m[05-31|11:45:19] Initializing provisioningServiceImpl ←[32mlogger←[0m=server
←[32mINFO←[0m[05-31|11:45:19] Initializing Stream Manager
←[32mINFO←[0m[05-31|11:45:19] HTTP Server Listen ←[32mlogger←[0m=http.server ←[32maddress←[0m=0.0.0.0:3000 ←[32mprotocol←[0m=http ←[32msubUrl←[0m= ←[32msocket←[0m=
please help.
thanks
i found 1 problem : i forgot this moment: " uncomment the http_port configuration option ( ; is the comment character in ini files) and change it to something like 8080 or similar."
i fixed this problem , but i found next problem
←[32mINFO←[0m[05-31|15:03:31] Executing migration ←[32mlogg
er←[0m=migrator ←[32mid←[0m=“Update quota table charset”
er←[0m=migrator ←[32mid←[0m=“create plugin_setting table”
er←[0m=migrator ←[32mid←[0m=“create index UQE_plugin_setting_org_id_plugin_id -
v1”
er←[0m=migrator ←[32mid←[0m=“Add column plugin_version to plugin_settings”
er←[0m=migrator ←[32mid←[0m=“Update plugin_setting table charset”
er←[0m=migrator ←[32mid←[0m=“create session table”
er←[0m=migrator ←[32mid←[0m=“Drop old table playlist table”
er←[0m=migrator ←[32mid←[0m=“Drop old table playlist_item table”
er←[0m=migrator ←[32mid←[0m=“create playlist table v2”
er←[0m=migrator ←[32mid←[0m=“create playlist item table v2”
er←[0m=migrator ←[32mid←[0m=“Update playlist table charset”
er←[0m=migrator ←[32mid←[0m=“Update playlist_item table charset”
er←[0m=migrator ←[32mid←[0m=“drop preferences table v2”
er←[0m=migrator ←[32mid←[0m=“drop preferences table v3”
er←[0m=migrator ←[32mid←[0m=“create preferences table v3”
er←[0m=migrator ←[32mid←[0m=“Update preferences table charset”
er←[0m=migrator ←[32mid←[0m=“Add column team_id in preferences”
er←[0m=migrator ←[32mid←[0m=“Update team_id column values in preferences”
er←[0m=migrator ←[32mid←[0m=“create alert table v1”
er←[0m=migrator ←[32mid←[0m="add index alert org_id & id "
er←[0m=migrator ←[32mid←[0m=“add index alert state”
er←[0m=migrator ←[32mid←[0m=“add index alert dashboard_id”
er←[0m=migrator ←[32mid←[0m=“create alert_notification table v1”
er←[0m=migrator ←[32mid←[0m=“Add column is_default”
er←[0m=migrator ←[32mid←[0m=“Add column frequency”
er←[0m=migrator ←[32mid←[0m=“Add column send_reminder”
er←[0m=migrator ←[32mid←[0m=“Add column disable_resolve_message”
er←[0m=migrator ←[32mid←[0m=“add index alert_notification org_id & name”
er←[0m=migrator ←[32mid←[0m=“Update alert table charset”
er←[0m=migrator ←[32mid←[0m=“Update alert_notification table charset”
er←[0m=migrator ←[32mid←[0m=“create notification_journal table v1”
er←[0m=migrator ←[32mid←[0m=“add index notification_journal org_id & alert_id &
notifier_id”
er←[0m=migrator ←[32mid←[0m=“drop alert_notification_journal”
er←[0m=migrator ←[32mid←[0m=“create alert_notification_state table v1”
er←[0m=migrator ←[32mid←[0m=“add index alert_notification_state org_id & alert_i
d & notifier_id”
er←[0m=migrator ←[32mid←[0m=“Add for to alert table”
er←[0m=migrator ←[32mid←[0m=“Add column uid in alert_notification”
er←[0m=migrator ←[32mid←[0m=“Update uid column values in alert_notification”
er←[0m=migrator ←[32mid←[0m=“Add unique index alert_notification_org_id_uid”
er←[0m=migrator ←[32mid←[0m=“Remove unique index org_id_name”
er←[0m=migrator ←[32mid←[0m=“Drop old annotation table v4”
er←[0m=migrator ←[32mid←[0m=“create annotation table v5”
er←[0m=migrator ←[32mid←[0m=“add index annotation 0 v3”
er←[0m=migrator ←[32mid←[0m=“add index annotation 1 v3”
er←[0m=migrator ←[32mid←[0m=“add index annotation 2 v3”
er←[0m=migrator ←[32mid←[0m=“add index annotation 3 v3”
er←[0m=migrator ←[32mid←[0m=“add index annotation 4 v3”
er←[0m=migrator ←[32mid←[0m=“Update annotation table charset”
er←[0m=migrator ←[32mid←[0m=“Add column region_id to annotation table”
er←[0m=migrator ←[32mid←[0m=“Drop category_id index”
er←[0m=migrator ←[32mid←[0m=“Add column tags to annotation table”
er←[0m=migrator ←[32mid←[0m=“Create annotation_tag table v2”
er←[0m=migrator ←[32mid←[0m=“Add unique index annotation_tag.annotation_id_tag_i
d”
er←[0m=migrator ←[32mid←[0m=“Update alert annotations and set TEXT to empty”
er←[0m=migrator ←[32mid←[0m=“Add created time to annotation table”
er←[0m=migrator ←[32mid←[0m=“Add updated time to annotation table”
er←[0m=migrator ←[32mid←[0m=“Add index for created in annotation table”
←[32mINFO←[0m[05-31|15:03:32] Executing migration ←[32mlogg
er←[0m=migrator ←[32mid←[0m=“Add index for updated in annotation table”
er←[0m=migrator ←[32mid←[0m=“Convert existing annotations from seconds to millis
econds”
er←[0m=migrator ←[32mid←[0m=“create test_data table”
er←[0m=migrator ←[32mid←[0m=“create dashboard_version table v1”
er←[0m=migrator ←[32mid←[0m=“add index dashboard_version.dashboard_id”
er←[0m=migrator ←[32mid←[0m=“add unique index dashboard_version.dashboard_id and
dashboard_version.version”
er←[0m=migrator ←[32mid←[0m=“Set dashboard version to 1 where 0”
er←[0m=migrator ←[32mid←[0m=“save existing dashboard data in dashboard_version t
able v1”
er←[0m=migrator ←[32mid←[0m=“alter dashboard_version.data to mediumtext v1”
er←[0m=migrator ←[32mid←[0m=“create team table”
er←[0m=migrator ←[32mid←[0m=“add index team.org_id”
er←[0m=migrator ←[32mid←[0m=“add unique index team_org_id_name”
er←[0m=migrator ←[32mid←[0m=“create team member table”
er←[0m=migrator ←[32mid←[0m=“add index team_member.org_id”
er←[0m=migrator ←[32mid←[0m="add unique index team_member_org_id_team_id_user_id
er←[0m=migrator ←[32mid←[0m=“Add column email to team table”
er←[0m=migrator ←[32mid←[0m=“Add column external to team_member table”
er←[0m=migrator ←[32mid←[0m=“Add column permission to team_member table”
er←[0m=migrator ←[32mid←[0m=“create dashboard acl table”
er←[0m=migrator ←[32mid←[0m=“add index dashboard_acl_dashboard_id”
er←[0m=migrator ←[32mid←[0m="add unique index dashboard_acl_dashboard_id_user_id
er←[0m=migrator ←[32mid←[0m="add unique index dashboard_acl_dashboard_id_team_id
er←[0m=migrator ←[32mid←[0m=“save default acl rules in dashboard_acl table”
er←[0m=migrator ←[32mid←[0m=“create tag table”
er←[0m=migrator ←[32mid←[0m=“add index tag.key_value”
er←[0m=migrator ←[32mid←[0m=“create login attempt table”
er←[0m=migrator ←[32mid←[0m=“add index login_attempt.username”
er←[0m=migrator ←[32mid←[0m=“drop index IDX_login_attempt_username - v1”
er←[0m=migrator ←[32mid←[0m=“Rename table login_attempt to login_attempt_tmp_qwe
rty - v1”
er←[0m=migrator ←[32mid←[0m=“create login_attempt v2”
er←[0m=migrator ←[32mid←[0m=“create index IDX_login_attempt_username - v2”
er←[0m=migrator ←[32mid←[0m=“copy login_attempt v1 to v2”
er←[0m=migrator ←[32mid←[0m=“drop login_attempt_tmp_qwerty”
er←[0m=migrator ←[32mid←[0m=“create user auth table”
er←[0m=migrator ←[32mid←[0m="create index IDX_user_auth_auth_module_auth_id - v1
er←[0m=migrator ←[32mid←[0m=“alter user_auth.auth_id to length 190”
er←[0m=migrator ←[32mid←[0m=“Add OAuth access token to user_auth”
er←[0m=migrator ←[32mid←[0m=“Add OAuth refresh token to user_auth”
er←[0m=migrator ←[32mid←[0m=“Add OAuth token type to user_auth”
er←[0m=migrator ←[32mid←[0m=“Add OAuth expiry to user_auth”
er←[0m=migrator ←[32mid←[0m=“Add index to user_id column in user_auth”
er←[0m=migrator ←[32mid←[0m=“create server_lock table”
er←[0m=migrator ←[32mid←[0m=“add index server_lock.operation_uid”
er←[0m=migrator ←[32mid←[0m=“create user auth token table”
er←[0m=migrator ←[32mid←[0m=“add unique index user_auth_token.auth_token”
er←[0m=migrator ←[32mid←[0m=“add unique index user_auth_token.prev_auth_token”
er←[0m=migrator ←[32mid←[0m=“create cache_data table”
er←[0m=migrator ←[32mid←[0m=“add unique index cache_data.cache_key”
←[32mINFO←[0m[05-31|15:03:32] Created default admin ←[32mlogg
er←[0m=sqlstore ←[32muser←[0m=admin
←[32mINFO←[0m[05-31|15:03:32] Initializing HTTPServer ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing InternalMetricsService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing RemoteCache ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing QuotaService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing LoginService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing PluginManager ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Starting plugin search ←[32mlogg
er←[0m=plugins
←[32mINFO←[0m[05-31|15:03:32] Plugin dir created ←[32mlogg
er←[0m=plugins ←[32mdir←[0m=C:\grafana-6.2.0.windows-amd64\grafana-6.2.0\data
\plugins
←[32mINFO←[0m[05-31|15:03:32] Initializing RenderingService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing AlertingService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing DatasourceCacheService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing HooksService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing SearchService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing ServerLockService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing TracingService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing UsageStatsService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing UserAuthTokenService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing CleanUpService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing NotificationService ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing provisioningServiceImpl ←[32mlogg
er←[0m=server
←[32mINFO←[0m[05-31|15:03:32] Initializing Stream Manager
←[32mINFO←[0m[05-31|15:03:32] HTTP Server Listen ←[32mlogg
er←[0m=http.server ←[32maddress←[0m=0.0.0.0:8980 ←[32mprotocol←[0m=http ←[32msub
←[32mINFO←[0m[05-31|15:03:51] Shutdown started ←[32mlogg
er←[0m=server ←[32mreason←[0m=“System signal: interrupt”
←[32mINFO←[0m[05-31|15:03:51] Stopped PluginManager ←[32mlogg
er←[0m=server ←[32mreason←[0m=“context canceled”
←[32mINFO←[0m[05-31|15:03:51] Stopped RenderingService ←[32mlogg
er←[0m=server ←[32mreason←[0m=nil
←[32mINFO←[0m[05-31|15:03:51] Stopped NotificationService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped TracingService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped InternalMetricsService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped provisioningServiceImpl ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped RemoteCache ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped UserAuthTokenService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped UsageStatsService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped Stream Manager
←[32mINFO←[0m[05-31|15:03:51] Stopped CleanUpService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped AlertingService ←[32mlogg
←[32mINFO←[0m[05-31|15:03:51] Stopped HTTPServer ←[32mlogg
←[31mEROR←[0m[05-31|15:03:51] Server shutdown ←[31mlogg
er←[0m=server ←[31mreason←[0m=“System signal: interrupt”
C:\grafana-6.2.0.windows-amd64\grafana-6.2.0\bin>
Step by step Guide to Installation of Grafana on Windows: TutorialandExample.com Covers a Grafana Tutorial and Installation Guides with steps.
