Grafana error after upgrade
After I upgraded from 8.2.2 to 9.1.2 none of my dashboards will load I get the following error
I just did the normal windows download install and every dashboard gives the same error. Never had this before.
Thanks in advance.
Did you do a restart of grafana?
Yes, I did restart, the problem was either the CLOCK PANEL version compatibility or maybe corruption during the upgrade.
I reinstalled the CLOCK PANEL and all is working ok now!
Thank you.
