No more CLOCK and DISCRETE plugins? I can not get it anymore.
is this aviable in the plugin section?
welcome to the
forum, @info7bef
what version of Grafana are you running and where are you running it? When I run 8.4.3 in a docker container I can add both panels using the internal plugin catalog:
thank´s for the reply
i run the latest version on a vm on a win pc. the plugins are there before in the catalog. now, i cant find them anymore. i think that they are removed in the list…
