How to render an image from an url value in Grafana Table column v7.1.4
Hi All,
In one of my table’s column, I have an url stored which is a link to an image. How can I render it as an image when it loads on the table. My data source is Grafana-Simple-JSON-Datasource output in table format. And I am using Table panel in Visualization to render the data.
Attached is the sample data output.
Looking forward to suggestions.
Hi All,
Found a way to solve this issue. I modified the url links as html tags, like this . And most importantly, I am using table panel from v6.x.x and Sanitize html option. The new table panels from v7.x.x does not have this option.
