Grafana OSS 11.0.0 -
I want to display an image from a url inside a table panel cell -
I load the image url from my datasource (clickhouse) in this case.
The link has the following form: http://myServer/mySite/2024/05/MyImage.jpg
I then use an override to change the cell type to image. -
What happened?
When changing from cell type auto to image the cell becomes blank/ empty without displaying an image. -
To see my image from the given url. -
I tried to inject the image via html configuration from the below community discussion, however without success.
How to display images from URL?
I had the same problem and solved it by adding a transformation “Convert field type” and converted the url field to String (it was number by default)
