I am using Grafana with Prometheus.
My problem is that I want to monitor a lot of hosts.
I would like to properly display UP and DOWN status, with the name of each host.
Prometheus gives a simple command : “up”.
I tested with 4 hosts, and this is what I got :
The left panel is pretty ugly and take too much time to clearly show a down status.
The right panel is much visual, but doesn’t show which host is up or down !
I am looking for a panel that could display these status with their hostname.
There is maybe a solution for the right panel in it’s configuration:
Maybe I could use the prefix/suffix. But I don’t know how.
Note for those who will read later : after installed a panel plugin, reload the web interface, otherwise the plugin will apear in the plugin list but not in the panel list.
Hey, how can i use this plugin with ALL option variable? Instead of creating one by one. When i used $HOSTS variable it just named my panel "“All” instead of naming the squares correctly.
