How to get Grafana server running without executing Grafana-server on macOS manually
    Grafana v9.2.1 | macOS Sonoma 14.2.1
    To have Grafana server running every time with no need to run Grafana/bin/grafana-server
  • What happened?
Create a service that runs grafana.
In windows we use nssm install
Not sure if there is an equivalent in mac
@maximilianosalibe
Alternative is running it as docker container. The container service can start automatically, dependent on the configuration, the container can auto start then as well.
On MacOS you can use Docker Desktop, but that requires a license when used in a company.
Alternatives are Podman Desktop and Rancher Desktop. Both provide the same functionality.
Podman yes!
Perhaps I could implement some of those solutions soon. But, for now, could you just tell me how can I stop grafana/bin/grafana-server once I’ve finished working? Thanks!
How did you start it and why do you want to stop it
I started on the terminal and I want to stop it because I need to close the terminal.
