Grafana v11.0.1 on macOS Sonoma 14.6.1 - What are you trying to achieve?
To start Grafana server as a service. - How are you trying to achieve it?
Creating a plist file in ~/Library/LaunchAgents - What happened?
Load fails. - What did you expect to happen?
The service to start. - Can you copy/paste the configuration(s) that you are having problems with?
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.grafana.server</string>
<key>ProgramArguments</key>
<array>
<string>/Users/maxsalibe/grafana-v11.0.1/bin/grafana server</string>
<string>--homepath</string>
<string>/Users/maxsalibe/grafana-v11.0.1</string>
</array>
<key>RunAtLoad</key>
<true/>
<key>KeepAlive</key>
<true/>
<key>StandardOutPath</key>
<string>/Users/maxsalibe/grafana-v11.0.1/logs/grafana-stdout.log</string>
<key>StandardErrorPath</key>
<string>/Users/maxsalibe/grafana-v11.0.1/logs/grafana-stderr.log</string>
</dict>
</plist>
