Grafana Service Not Starting
    Grafana version - NA
OS Fedora Linux
    Start Grafana after reboot
    Reboot and manually start
  • What happened?
    Starting the grafana-server.service failed
Job for grafana-server.service failed because the control process exited with error code.
grafana-server.service: Start request repeated too quickly.
grafana-server.service: Failed with result β€˜exit-code’.
welcome to the :grafana: community @dpell352
could you list the installation steps you followed and in what order please?
Unfortunately, I don’t have that information. I inherited this system from a former employee who set the system up. It was working until a recent system reboot.
Hi @dpell352
Please change the default log level to debug mode. To do this go to the server where grafana is installed and edit the configuration file (/etc/grafana/grafana.ini)
There you will this section;
#################################### Logging ##########################
[log]
# Either "console", "file", "syslog". Default is console and  file
# Use space to separate multiple modes, e.g. "console file"
;mode = console file
# Either "debug", "info", "warn", "error", "critical", default is "info"
;level = info
Set the parameter level to debug and remove the colon in the beginning i.e.
level = debug
Then restart the grafana service and resent the logs once the issue occurs again.
Thanks. I’ll send the log when it’s complete.
This is all I’m seeing in Grafana.log
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.457469663-05:00 level=info msg="Request Completed" method=GET path=/api/login/ping status=4>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.459278576-05:00 level=info msg="Request Completed" method=GET path=/api/login/ping status=4>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.464896666-05:00 level=info msg="Request Completed" method=GET path=/api/login/ping status=4>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.466167572-05:00 level=info msg="Request Completed" method=GET path=/api/login/ping status=4>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.505683019-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.508589069-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.511760902-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.512761695-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.542468192-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.543293932-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=context userId=0 orgId=0 uname= t=2023-01-06T08:57:34.571457709-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=cleanup t=2023-01-06T08:59:37.934330167-05:00 level=info msg="Completed cleanup jobs" duration=140.734484ms
logger=cleanup t=2023-01-06T09:09:37.931728634-05:00 level=info msg="Completed cleanup jobs" duration=138.426633ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T09:14:47.871094257-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T09:15:04.650606254-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=cleanup t=2023-01-06T09:19:37.91246629-05:00 level=info msg="Completed cleanup jobs" duration=118.958888ms
logger=cleanup t=2023-01-06T09:29:37.926491179-05:00 level=info msg="Completed cleanup jobs" duration=133.662499ms
logger=cleanup t=2023-01-06T09:39:37.882212966-05:00 level=info msg="Completed cleanup jobs" duration=89.57595ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T09:44:48.395140552-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T09:45:05.216555467-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=cleanup t=2023-01-06T09:49:37.921153699-05:00 level=info msg="Completed cleanup jobs" duration=128.495513ms
logger=cleanup t=2023-01-06T09:59:37.893311365-05:00 level=info msg="Completed cleanup jobs" duration=100.65203ms
logger=cleanup t=2023-01-06T10:09:37.932718957-05:00 level=info msg="Completed cleanup jobs" duration=139.31008ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T10:14:48.927203827-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T10:15:05.753862495-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=cleanup t=2023-01-06T10:19:37.904664342-05:00 level=info msg="Completed cleanup jobs" duration=111.86552ms
logger=cleanup t=2023-01-06T10:29:37.910698169-05:00 level=info msg="Completed cleanup jobs" duration=117.333726ms
logger=cleanup t=2023-01-06T10:39:37.899870595-05:00 level=info msg="Completed cleanup jobs" duration=107.068824ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T10:44:49.477231087-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T10:45:06.291987994-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=cleanup t=2023-01-06T10:49:38.038800055-05:00 level=info msg="Completed cleanup jobs" duration=246.2496ms
logger=cleanup t=2023-01-06T10:59:37.886230957-05:00 level=info msg="Completed cleanup jobs" duration=92.800627ms
logger=cleanup t=2023-01-06T11:09:37.916801517-05:00 level=info msg="Completed cleanup jobs" duration=123.435136ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T11:14:50.004149945-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T11:15:06.85830048-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature->
logger=cleanup t=2023-01-06T11:19:37.930907161-05:00 level=info msg="Completed cleanup jobs" duration=137.487827ms
logger=http.server t=2023-01-06T11:20:07.587335008-05:00 level=info msg="Successful Login" User=admin@localhost
logger=context userId=1 orgId=1 uname=admin t=2023-01-06T11:20:12.014878786-05:00 level=info msg="Request Completed" method=GET path=/api/live/ws status>
logger=cleanup t=2023-01-06T11:29:37.886272-05:00 level=info msg="Completed cleanup jobs" duration=92.887411ms
logger=cleanup t=2023-01-06T11:39:37.925713855-05:00 level=info msg="Completed cleanup jobs" duration=132.226691ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T11:44:50.540907349-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T11:45:07.383673874-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=cleanup t=2023-01-06T11:49:37.90625375-05:00 level=info msg="Completed cleanup jobs" duration=113.177455ms
logger=cleanup t=2023-01-06T11:59:37.895299173-05:00 level=info msg="Completed cleanup jobs" duration=101.990411ms
logger=context t=2023-01-06T12:00:13.788151078-05:00 level=warn msg="failed to look up session from cookie" error="user token not found"
logger=context userId=0 orgId=0 uname= t=2023-01-06T12:00:13.788437805-05:00 level=info msg="Request Completed" method=POST path=/api/ds/query status=40>
logger=context userId=0 orgId=0 uname= t=2023-01-06T12:00:13.809064538-05:00 level=info msg="Request Completed" method=GET path=/api/login/ping status=4>
logger=context userId=0 orgId=0 uname= t=2023-01-06T12:00:13.951003808-05:00 level=info msg="Request Completed" method=GET path=/d/78H_EfOnz/stations-ir>
logger=context userId=1 orgId=1 uname=admin t=2023-01-06T12:00:14.053008157-05:00 level=info msg="Request Completed" method=GET path=/login status=302 r>
logger=context userId=1 orgId=1 uname=admin t=2023-01-06T12:00:14.249604953-05:00 level=info msg="Request Completed" method=GET path=/api/live/ws status>
logger=cleanup t=2023-01-06T12:09:37.901043254-05:00 level=info msg="Completed cleanup jobs" duration=107.99092ms
logger=context userId=0 orgId=0 uname= t=2023-01-06T12:14:51.093986316-05:00 level=info msg="Request Completed" method=GET path=/d/mgMkEBO7k/stations-ir>
logger=context userId=0 orgId=0 uname= t=2023-01-06T12:15:07.907802874-05:00 level=info msg="Request Completed" method=GET path=/d/P7aiA0W4z/temperature>
logger=cleanup t=2023-01-06T12:19:37.872912035-05:00 level=info msg="Completed cleanup jobs" duration=80.199626ms
logger=cleanup t=2023-01-06T12:29:38.045722835-05:00 level=info msg="Completed cleanup jobs" duration=252.069475ms
Ok so the log level is still info (which is the default)
Did you set restart the grafana service after setting
level = debug
in the grafana.conf file?
Also, what Operating System you are using?
The OS is Fedora 36. I’m not able to find the Grafana.conf file. Where would it be located?
Ok I made a typo mistake in the file path (in my initial post to change the log level to debug mode)
So on my CentOS machine (which is v.similar to Fedora)
[root@grafana ~]# whereis grafana
grafana: /etc/grafana /usr/share/grafana
Then I go into this directory
[root@grafana ~]# cd /etc/grafana/
[root@grafana grafana]# ls -l
total 60
-rw-r----- 1 root grafana 47149 Jan  5 11:02 grafana.ini
Now, this is the default configuration file. Open it in an editor and change the log level to debug mode (as explained earlier).
Restart the grafana service
[root@grafana grafana]# systemctl restart grafana-server
Check the status after the restart
[root@grafana grafana]# systemctl status grafana-server
(Paste all the data here)
Then getting and pasting the logs from /var/log/grafana/grafana.log
Ok. I’ll give it a try.
Thanks
w[eng@ewswi30000511 /]$ whereis grafana
[eng@ewswi30000511 /]$ cd /etc/grafana/
[eng@ewswi30000511 grafana]$ ls -l
total 120
-rw-r--r--. 1 root grafana 66121 Jan 9 10:32 grafana.ini
-rw-r-----. 1 root grafana 48282 Dec 30 14:22 grafana.ini.save
-rw-r-----. 1 root grafana 2376 Aug 24 12:49 ldap.toml
drwxr-xr-x. 1 root grafana 118 Aug 24 12:49 provisioning
[eng@ewswi30000511 grafana]$ sudo nano grafana.ini
[sudo] password for eng:
[eng@ewswi30000511 grafana]$ sudo systemctl restart grafana-server
See "systemctl status grafana-server.service" and "journalctl -xeu grafana-server.service" for details.
[eng@ewswi30000511 grafana]$ sudo systemctl status grafan-server
Unit grafan-server.service could not be found.
Here’s the end of the log file:
logger=settings t=2023-01-06T14:52:54.983264603-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:52:55.472081827-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:52:55.764607025-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:52:56.231602354-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:53:10.219152547-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:53:10.483694934-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:53:10.972308835-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:53:11.264154418-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:53:11.764957648-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:57:51.906686891-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:57:52.267987831-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:57:52.73822074-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:57:53.225562097-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T14:57:53.730400105-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:52.602798972-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:52.995415075-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:53.488726431-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:53.949697133-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:54.23912038-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:54.744774774-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-06T15:03:55.244311129-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:36:28.667699667-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:36:28.971554316-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:36:29.453208415-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:36:29.751605947-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:36:30.208351076-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:38:52.41756135-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:38:52.752390439-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:38:53.212127891-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:38:53.710341503-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:38:54.247908232-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:42:16.946690186-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:42:17.251450687-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:42:17.713997949-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:42:18.247359418-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:42:18.708813752-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:49:37.426990794-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:49:37.755183028-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:49:38.206756138-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:49:38.453988023-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T10:49:38.745880662-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:25.822715278-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:26.151830991-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:26.520282501-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:27.020560261-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:27.507266248-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:28.025114804-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:28.506160911-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:29.024544982-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:29.488470923-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-09T12:26:29.87925403-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-10T07:52:13.628242191-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-10T07:52:13.992084647-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-10T07:52:14.52671851-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-10T07:52:14.979760297-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
logger=settings t=2023-01-10T07:52:15.24110717-05:00 level=error msg="failed to parse \"/etc/grafana/grafana.ini\": key-value delimiter not found: afs boot etc lib lost+found >
This is a very strange message as never seen such a thing before.
Please run the command and paste the output;
Also check if you have enough disk space (command is df -h) on the server and enough free memory (command is free -mh)
[eng@ewswi30000511 grafana]$ sudo journalctl -xeu grafana-server.service
Jan 10 07:52:15  systemd[1]: grafana-server.service: Failed with result 'exit-code'.
β–‘β–‘ Subject: Unit failed
β–‘β–‘ Defined-By: systemd
β–‘β–‘
β–‘β–‘ The unit grafana-server.service has entered the 'failed' state with result 'exit-code'.
Jan 10 07:52:15  systemd[1]: Failed to start grafana-server.service - Grafana instance.
β–‘β–‘ Subject: A start job for unit grafana-server.service has failed
β–‘β–‘
β–‘β–‘ A start job for unit grafana-server.service has finished with a failure.
β–‘β–‘
β–‘β–‘ The job identifier is 6356 and the job result is failed.
Jan 10 07:52:15  systemd[1]: grafana-server.service: Scheduled restart job, restart counter>
β–‘β–‘ Subject: Automatic restarting of a unit has been scheduled
β–‘β–‘
β–‘β–‘ Automatic restarting of the unit grafana-server.service has been scheduled, as the result for
β–‘β–‘ the configured Restart= setting for the unit.
Jan 10 07:52:15  systemd[1]: Stopped grafana-server.service - Grafana instance.
β–‘β–‘ Subject: A stop job for unit grafana-server.service has finished
β–‘β–‘
β–‘β–‘ A stop job for unit grafana-server.service has finished.
β–‘β–‘
β–‘β–‘ The job identifier is 6470 and the job result is done.
Jan 10 07:52:15  systemd[1]: grafana-server.service: Start request repeated too quickly.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 6470 and the job result is failed.
[eng@ewswi30000511 grafana]$ df -h
Filesystem      Size  Used Avail Use% Mounted on
devtmpfs        4.0M     0  4.0M   0% /dev
tmpfs           7.8G     0  7.8G   0% /dev/shm
tmpfs           3.1G  1.2M  3.1G   1% /run
/dev/sda3       930G  6.2G  923G   1% /
tmpfs           7.8G     0  7.8G   0% /tmp
/dev/sda3       930G  6.2G  923G   1% /home
/dev/sda2       974M  267M  640M  30% /boot
/dev/sda1       599M   18M  582M   3% /boot/efi
tmpfs           1.6G   48K  1.6G   1% /run/user/988
tmpfs           1.6G   48K  1.6G   1% /run/user/1000
[eng@ewswi30000511 grafana]$ free -mh
               total        used        free      shared  buff/cache   available
Mem:            15Gi       830Mi        11Gi        12Mi       3.1Gi        14Gi
Swap:          8.0Gi          0B       8.0Gi
please post your grafana.ini content minus sensitive stuff
what version grafana is it? And does it use grafana.db sqllite?
Ok, both disk space and memory look good.
I think then the issue is definitely with your grafana.ini configuration file. Somewhere there is a line which is not recognizable by the service.
I found this similar post where your error message is looks like a match. Please have a look and I think you understand it too that either uncommenting a line in the grafana.ini file did not go correctly.
If you can’t figure it out then as @yosiasz suggested, post your complete grafana.ini file so we can view it.
As the previous poster said - you have an error in your grafana.ini
Search the file for afs boot etc lib as that is where the error is.
Thanks. I’ll have a look and update the post.
Thanks. I’ll have a look.
Thanks for all the help. The system is up and running. I looked at grafana.ini and didn’t see anything out of order. I created a new file to replace the existing. After replacing it, everything worked as it should.
Again, thanks for the assistance.
