I am trying to setup Grafana for rootless, but i am stuck because when i mount the folders in the corresponding partition it won’t populate the folders with the Grafana container files, i am new in container, that’s why here i am looking for a little help with this setup.
My script:
# Create Folder in user
mkdir -p "${PWD}"/data/{config,data,grafana,logs,plugins}
mkdir .enc
# Credentials
USERs=USER_ADMIN
## Generate Password
PASS=$(openssl rand -base64 12)
### Create secret for password and user
echo "${USERs}" >.enc/user && podman secret create "$(echo "${USERs}" | openssl enc -e -a -base64 | sed 's/[^a-zA-Z0-9]*$//')" .enc/user
echo "${PASS}" >.enc/pass && podman secret create "$(echo "${PASS}" | openssl enc -e -a -base64 | sed 's/[^a-zA-Z0-9]*$//')" .enc/pass
podman run -dt \
--user "$(id -u)" \
-p 3000:3000 \
--name grafana \
--secret "$(echo "${USERs}" | openssl enc -e -a -base64 | sed 's/[^a-zA-Z0-9]*$//')" \
--secret "$(echo "${PASS}" | openssl enc -e -a -base64 | sed 's/[^a-zA-Z0-9]*$//')" \
-v "${PWD}"/data/config:/etc/grafana:rw \
-v "${PWD}"/data/data:/var/lib/grafana:U,rw \
-v "${PWD}"/data/grafana:/usr/share/grafana:rw \
-v "${PWD}"/data/logs:/var/log/grafana:rw \
-v "${PWD}"/data/plugins:/var/lib/grafana/plugins:rw \
-e "GF_SECURITY_ADMIN_PASSWORD__FILE=/run/secrets/$(echo "${PASS}" | openssl enc -e -a -base64 | sed 's/[^a-zA-Z0-9]*$//')" \
-e "GF_SECURITY_ADMIN_USER__FILE=/run/secrets/$(echo "${USERs}" | openssl enc -e -a -base64 | sed 's/[^a-zA-Z0-9]*$//')" \
-e "GF_DEFAULT_INSTANCE_NAME=EYES" \
-e "GF_SERVER_PROTOCOL=h2" \
-e "GF_SERVER_ENABLE_GZIP=true" \
-e "GF_FEATURE_TOGGLES_ENABLE=publicDashboards" \
-e "GF_INSTALL_PLUGINS=grafana-clock-panel, citilogics-geoloop-panel, gowee-traceroutemap-panel, alexanderzobnin-zabbix-app" \
-e "GF_LOG_MODE=console file" \
docker.io/grafana/grafana-enterprise
Now the issues is/are (will update in the progress):
- The folders are not filled with grafana container contents, this creates the error
GF_PATHS_CONFIG='/etc/grafana/grafana.ini' is not readable.
Welcome
Looks like you did not provide that env var? And since it errored the rest of the issues are non-issues
the issue is not the environment, the issue i am facing is, the container is not populating the folders, if i use the container without permanent storage everything works, but if i try setting permanent storage, Grafana it won’t populate the corresponding files in those folders.
So, when it said it is not readable, the file does not exist.
You didn’t create grafana.ini file
Hoping, that like some others containers, populated the volumes with the defaults files that bring the container.
i was hoping, getting the file from the container, and not to have to add one manually (this can be used? https://github.com/grafana/grafana/blob/main/conf/defaults.ini) , because i was hoping contribute this script, for users to easily deploy single cluster Grafana service.
Container has own default grafana.ini file, but you are overwriting that config folder by custom volume, so you have to provide grafana.ini in that folder/volume.
which method can i use to “not overwrite”?, because some folders a created but not files are maintained.
Simole.Don’t use config volume, so you won’t overwrite default grafana.ini
I guess your next question: how can I configure Grafana then?
1.) use the config volume, but provide grafana.ini there
2.) use env variables for a Grafana configuration
I would recommend to check doc: https://grafana.com/docs/grafana/latest/setup-grafana/installation/docker/
well don’t know how the Grafana container is build, but here is the final code:
#!/usr/bin/env bash
# -*- coding: utf-8 -*-
mkdir -p "${PWD}"/data/{config,data,grafana,logs}
mkdir .enc
# Volume Management
## This will point the mount to the folder and store the info there
podman volume create \
-o device="${PWD}"/data/config \
-o=o=bind \
config_grafana
-o device="${PWD}"/data/Grafana \
-o=o=bind \
home_grafana
# Credentials
USERs=name
PASS=$(openssl rand -base64 12) && echo "$PASS"
podman rm -f grafana
podman run -dt \
--user "$(id -u)" \
-p 3000:3000 \
--name grafana \
-v "${PWD}"/data/data:/var/lib/grafana:U \
-v "${PWD}"/data/logs:/var/log/grafana \
-v config_grafana:/etc/grafana \
-v home_grafana:/usr/share/grafana \
podman logs Grafana
