Config is not readable using PUID 472 and PGID 0
    grafana/grafana:latest using docker 20.10.17 and docker-compose 1.29.2 running on 5.18.0-1-amd64 Debian 5.18.2-1 (2022-06-06) x86_64 GNU/Linux
    Set up an instance of Grafana with access to grafana.ini in a locally mounted folder
    Used a docker-compose.yml file and a .env file to manage configuration
  • What happened?
    The following errors in the log file:
$ docker-compose --file /srv/grafana/docker-compose.yml logs
Attaching to grafana
grafana    | GF_PATHS_CONFIG='/srv/grafana/config' is not readable.
grafana    | GF_PATHS_DATA='/srv/grafana/data' is not writable.
grafana    | You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migrate-to-v51-or-later
grafana    | logger=settings t=2022-11-22T17:18:14.42336638Z level=error msg="failed to parse \"/srv/grafana/config\": open /srv/grafana/config: no such file or directory"
    For the container to start normally
    docker-compose.yml:
version: "3"
services:
  grafana:
    image: grafana/grafana-oss:latest
    container_name: grafana
    hostname: ${HOSTNAME}
    user: ${PUID}:${PGID}
    environment:
      - GF_PATHS_CONFIG=${APPDATA}/config
      - GF_PATHS_DATA=${APPDATA}/data
    volumes:
      - ${APPDATA}/config:/etc/grafana/
      - ${APPDATA}/config/grafana.ini:/etc/grafana/grafana.ini # test
      - ${APPDATA}/data:/var/lib/grafana
    ports:
      - "3000:3000"
    restart: always
.env file:
# User ID and Group ID
PUID=472
PGID=0
# Directory locations
APPDATA=/srv/grafana
# Host specifics
HOSTNAME=services
Steps followed to create environment:
$ cd /srv/grafana
$ mkdir config/ data/
$ sudo chown -R 472:0 config/ data/
$ ls -la
total 48
drwxr-xr-x  8 idsvc idsvc 4096 Nov 22 10:29 .
drwxr-xr-x 34 idsvc idsvc 4096 Nov 22 10:12 ..
drwxr-xr-x  2   472 root  4096 Nov 22 10:29 config
drwxr-xr-x  2   472 root  4096 Nov 22 10:29 data
-rw-r--r--  1 idsvc idsvc 1482 Nov 22 10:15 docker-compose.yml
-rw-r--r--  1 idsvc idsvc  287 Nov 22 10:18 .env
Confirmation of configuration:
$ docker-compose --file /srv/grafana/docker-compose.yml config
services:
  grafana:
    environment:
      GF_PATHS_CONFIG: /srv/grafana/config
      GF_PATHS_DATA: /srv/grafana/data
    hostname: services
    ports:
    - published: 3000
      target: 3000
    restart: always
    user: '472:0'
    volumes:
    - /srv/grafana/config:/etc/grafana:rw
    - /srv/grafana/config/grafana.ini:/etc/grafana/grafana.ini:rw
    - /srv/grafana/data:/var/lib/grafana:rw
version: '3'
Environment values from running container:
$ docker exec grafana env
PATH=/usr/share/grafana/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
HOSTNAME=services
GF_PATHS_CONFIG=/srv/grafana/config
GF_PATHS_DATA=/srv/grafana/data
GF_PATHS_HOME=/usr/share/grafana
GF_PATHS_LOGS=/var/log/grafana
GF_PATHS_PLUGINS=/var/lib/grafana/plugins
GF_PATHS_PROVISIONING=/etc/grafana/provisioning
HOME=/home/grafana
Mounts from running container:
$ docker container inspect grafana -f '{{range .Mounts}}{{.Type}}:{{.Source}}:{{.Destination}}{{println}}{{ end }}'
bind:/srv/grafana/config/grafana.ini:/etc/grafana/grafana.ini
bind:/srv/grafana/config:/etc/grafana
bind:/srv/grafana/data:/var/lib/grafana
I have followed the direction to use user 472 (grafana) and group 0 (root). I expected grafana.ini to be created on initial run.
Issue resolved.
Container Configuration
These command were used to set up the environment:
cd /srv/grafana
mkdir config/ data/ logs/
docker run --rm --entrypoint /bin/bash grafana/grafana-oss:latest -c 'cat $GF_PATHS_CONFIG' > grafana.ini
mv grafana.ini config/
sudo chown -R 472:0 config/ data/ logs/
docker-compose --file /srv/grafana/docker-compose.yml up --detach
This process creates the directories that will be used to mount the hosted volumes, then grabs a copy of the grafana.ini file from the same grafana version used in the docker-compose.yml file and places it in the appropriate directory. Ownership of all the directories and contents is then set to the grafana user and root group.
Docker Compose
The following is the docker-compose.yml used:
version: "3"
services:
  grafana:
    volumes:
      - ${APPDATA}/logs:/var/log/grafana
    ports:
      - "3000:3000"
    restart: always
The following is the .env used:
PUID=472
PGID=0
# Timezone from https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
TZ=America/Edmonton
# Host specifics
HOSTNAME=id-services
Note that the user: setting in the docker-compose.yml has been removed.
The direction I found is to either run the container as the current user added to the docker group, or by preference change the ownership to user grafana (472) and group root (0). Grabbing a blank copy of the grafana.ini file before first launch then changing ownership was what was missing.
