Grafana container using bind mounts not working
hi,
i’m trying to run a fresh new docker container of grafana 5.1.0 with bind mounts on a freshly installed default centos7 minimal. working with root account.
doing exactly as the documentation said, and i still have permission problems,
it’s really frustrating,
what can i do ?
1.) You already duplicate your issue: Grafana 5.1.0 docker image - cant handle the permissions
2.) You are not providing full steps for replicating of your problems
3.) It works on my computer, so please try to copy paste all these steps below on your computer and then improve them for your use case:
[root@dockerhost ~]# mkdir host-data-folder && chmod 777 host-data-folder
[root@dockerhost ~]# docker run --name grafana -d  --volume "$PWD/host-data-folder:/var/lib/grafana" -p 3000:3000 grafana/grafana:5.1.2
dca10bfb48093ca706ed4412bf5ec1e2321b3f64474aba94c0f6e62c75378cbd
[root@dockerhost ~]# docker logs -f grafana
t=2018-05-14T10:57:30+0000 lvl=info msg="Starting Grafana" logger=server version=5.1.2 commit=c3c690e21 compiled=2018-05-09T09:00:18+0000
t=2018-05-14T10:57:30+0000 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2018-05-14T10:57:30+0000 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.data=/var/lib/grafana"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.logs=/var/log/grafana"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.log.mode=console"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_DATA=/var/lib/grafana"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_LOGS=/var/log/grafana"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
t=2018-05-14T10:57:30+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
t=2018-05-14T10:57:30+0000 lvl=info msg="Path Home" logger=settings path=/usr/share/grafana
t=2018-05-14T10:57:30+0000 lvl=info msg="Path Data" logger=settings path=/var/lib/grafana
t=2018-05-14T10:57:30+0000 lvl=info msg="Path Logs" logger=settings path=/var/log/grafana
t=2018-05-14T10:57:30+0000 lvl=info msg="Path Plugins" logger=settings path=/var/lib/grafana/plugins
t=2018-05-14T10:57:30+0000 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
t=2018-05-14T10:57:30+0000 lvl=info msg="App mode production" logger=settings
t=2018-05-14T10:57:30+0000 lvl=info msg="Initializing DB" logger=sqlstore dbtype=sqlite3
t=2018-05-14T10:57:30+0000 lvl=info msg="Starting DB migration" logger=migrator
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create migration_log table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create user table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index user.login"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index user.email"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_user_login - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_user_email - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Rename table user to user_v1 - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create user table v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_user_login - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_user_email - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="copy data_source v1 to v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table user_v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column help_flags1 to user table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update user table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add last_seen_at column to user"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create temp user table v1-7"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_email - v1-7"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_org_id - v1-7"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_code - v1-7"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_temp_user_status - v1-7"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update temp_user table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create star table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index star.user_id_dashboard_id"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create org table v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_org_name - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create org_user table v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_org_user_org_id - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_org_user_org_id_user_id - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="copy data account to org"
t=2018-05-14T10:57:30+0000 lvl=info msg="Skipping migration condition not fulfilled" logger=migrator id="copy data account to org"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="copy data account_user to org_user"
t=2018-05-14T10:57:30+0000 lvl=info msg="Skipping migration condition not fulfilled" logger=migrator id="copy data account_user to org_user"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table account"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table account_user"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update org table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update org_user table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Migrate all Read Only Viewers to Viewers"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add index dashboard.account_id"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_account_id_slug"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard_tag table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_tag.dasboard_id_term"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_dashboard_tag_dashboard_id_term - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Rename table dashboard to dashboard_v1 - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_org_id - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_dashboard_org_id_slug - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="copy dashboard v1 to v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop table dashboard_v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="alter dashboard.data to mediumtext v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column updated_by in dashboard - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column created_by in dashboard - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column gnetId in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add index for gnetId in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column plugin_id in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add index for plugin_id in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add index for dashboard_id in dashboard_tag"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update dashboard table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update dashboard_tag table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column folder_id in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column isFolder in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column has_acl in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column uid in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update uid column values in dashboard"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add unique index dashboard_org_id_uid"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Remove unique index org_id_slug"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update dashboard title length"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add unique index for dashboard_org_id_title_folder_id"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard_provisioning"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Rename table dashboard_provisioning to dashboard_provisioning_tmp_qwerty - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard_provisioning v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_provisioning_dashboard_id - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_provisioning_dashboard_id_name - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="copy dashboard_provisioning v1 to v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop dashboard_provisioning_tmp_qwerty"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create data_source table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add index data_source.account_id"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index data_source.account_id_name"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_data_source_account_id - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_data_source_account_id_name - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Rename table data_source to data_source_v1 - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create data_source table v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_data_source_org_id - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_data_source_org_id_name - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table data_source_v1 #2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column with_credentials"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add secure json data column"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update data_source table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update initial version to 1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add read_only data column"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create api_key table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add index api_key.account_id"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add index api_key.key"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="add index api_key.account_id_name"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_api_key_account_id - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_api_key_key - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop index UQE_api_key_account_id_name - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Rename table api_key to api_key_v1 - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create api_key table v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_api_key_org_id - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_api_key_key - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_api_key_org_id_name - v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="copy api_key v1 to v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table api_key_v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update api_key table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard_snapshot table v4"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="drop table dashboard_snapshot_v4 #1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard_snapshot table v5 #2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_dashboard_snapshot_key - v5"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_dashboard_snapshot_delete_key - v5"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_dashboard_snapshot_user_id - v5"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="alter dashboard_snapshot to mediumtext v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update dashboard_snapshot table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create quota table v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_quota_org_id_user_id_target - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update quota table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create plugin_setting table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create index UQE_plugin_setting_org_id_plugin_id - v1"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Add column plugin_version to plugin_settings"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update plugin_setting table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create session table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table playlist table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old table playlist_item table"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create playlist table v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="create playlist item table v2"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update playlist table charset"
t=2018-05-14T10:57:30+0000 lvl=info msg="Executing migration" logger=migrator id="Update playlist_item table charset"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="drop preferences table v2"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="drop preferences table v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create preferences table v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Update preferences table charset"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create alert table v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index alert org_id & id "
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index alert state"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index alert dashboard_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create alert_notification table v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Add column is_default"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index alert_notification org_id & name"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Update alert table charset"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Update alert_notification table charset"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Drop old annotation table v4"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create annotation table v5"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index annotation 0 v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index annotation 1 v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index annotation 2 v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index annotation 3 v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index annotation 4 v3"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Update annotation table charset"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Add column region_id to annotation table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Drop category_id index"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Add column tags to annotation table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Create annotation_tag table v2"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Add unique index annotation_tag.annotation_id_tag_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Update alert annotations and set TEXT to empty"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create test_data table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard_version table v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index dashboard_version.dashboard_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_version.dashboard_id and dashboard_version.version"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Set dashboard version to 1 where 0"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="save existing dashboard data in dashboard_version table v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="alter dashboard_version.data to mediumtext v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create team table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index team.org_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index team_org_id_name"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create team member table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index team_member.org_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index team_member_org_id_team_id_user_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Add column email to team table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create dashboard acl table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index dashboard_acl_dashboard_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_acl_dashboard_id_user_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add unique index dashboard_acl_dashboard_id_team_id"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="save default acl rules in dashboard_acl table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create tag table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index tag.key_value"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create login attempt table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="add index login_attempt.username"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="drop index IDX_login_attempt_username - v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="Rename table login_attempt to login_attempt_tmp_qwerty - v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create login_attempt v2"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_login_attempt_username - v2"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="copy login_attempt v1 to v2"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="drop login_attempt_tmp_qwerty"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create user auth table"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="create index IDX_user_auth_auth_module_auth_id - v1"
t=2018-05-14T10:57:31+0000 lvl=info msg="Executing migration" logger=migrator id="alter user_auth.auth_id to length 190"
t=2018-05-14T10:57:31+0000 lvl=info msg="Created default admin user: admin"
t=2018-05-14T10:57:31+0000 lvl=info msg="Starting plugin search" logger=plugins
t=2018-05-14T10:57:31+0000 lvl=info msg="Initializing Alerting" logger=alerting.engine
t=2018-05-14T10:57:31+0000 lvl=info msg="Initializing CleanUpService" logger=cleanup
t=2018-05-14T10:57:31+0000 lvl=info msg="Initializing Stream Manager"
t=2018-05-14T10:57:31+0000 lvl=info msg="Initializing HTTP Server" logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
^C
How do FS permissions look at the end?
[root@dockerhost ~]# ls -latr host-data-folder/
total 396
dr-xr-x---. 52 root root   4096 May 14 11:57 ..
drwxr-xr-x.  2  472  472      6 May 14 11:57 plugins
-rw-r--r--.  1  472  472 393216 May 14 11:57 grafana.db
drwxrwxrwx.  3 root root     37 May 14 11:57 .
hi,
i did exactly what you asked, check this out:
Pls provide output of your docker info.
here:
It’s there:
WARNING: You're not using the default seccomp profile.
Your docker is not default installation. It has configured additional security features.
Disable them or configure them in /etc/docker/seccomp.json properly.
IMHO seccomp configuration is not in the scope of Grafana - use Docker doc: https://docs.docker.com/engine/security/seccomp/
how did that get there :slightly_smiling_face:
any how, i fixed that issue, but permission problem still the same :frowning:
just tried it on a third machine, and it worked,
i wonder whats the issue with this lab…
thanks anyhow.
Problem can be:
  • Docker version (latest stable is 18.05)
  • storage driver (devicemapper vs overlay2)
  • Selinux (check /var/log/audit/audit.log)
