I’m trying to implement provisioning as described here for my Docker container so it can automatically connect to the datasource and bring up a few default dashboards.
I’m on Raspberry Pi OS Lite (Buster 10) and Docker version 20.10.6.
When I create a new container, I see in the Docker logs:
$ docker logs grafana -n 1000
GF_PATHS_CONFIG='/etc/grafana/grafana.ini' is not readable.
GF_PATHS_DATA='/var/lib/grafana' is not writable.
GF_PATHS_HOME='/usr/share/grafana' is not readable.
You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migrate-to-v51-or-later
So, Grafana isn’t able to pull my provisioning files out of /usr/share/grafana/conf/provisioning/, and I am left with an un-provisioned container.
Here’s how I’m creating the new container. I have tried a variety of --user settings when creating the container as recommended by the link in the log message above, and some other questions I’ve found relating to this issue, to no avail.
docker run -d --restart always --name grafana -p 3000:3000 --user 472:0 -v /home/pi/grafana-provisioning:/usr/share/grafana/conf/provisioning grafana/grafana:8.2.2
As you can see, I am mapping the local directory /home/pi/grafana-provisioning/ to the provisioning folder inside the container.
The permissions and ownership on the local grafana-provisioning directory are set very liberally:
$ ls -lsht
total 296K
4.0K drwxrwxrwx 4 pi pi 4.0K Oct 29 12:18 grafana-provisioning
As are the contents inside…
$ ls -lsht grafana-provisioning/
total 8.0K
4.0K drwxrwxrwx 2 pi pi 4.0K Oct 29 12:08 datasources
4.0K drwxrwxrwx 2 pi pi 4.0K Oct 29 12:08 dashboards
I have tried various UID and GID settings (removing the container and recreating it between each attempt). All the options I’ve tried result in the same permissions log entries.
Looking inside the docker container, the /usr/share/grafana directory is owned by root:
$ ls -lsht
total 28K
4 drwxr-xr-x 1 root root 4.0K Oct 21 2021 grafana
… As are the files and folders inside it:
$ ls -lsht grafana/
total 68K
4 -rw-r--r-- 1 root root 5 Oct 21 2021 VERSION
4 drwxr-xr-x 2 root root 4.0K Oct 21 2021 bin
4 drwxr-xr-x 3 root root 4.0K Oct 21 2021 conf
4 drwxr-xr-x 3 root root 4.0K Oct 21 2021 plugins-bundled
4 drwxr-xr-x 2 root root 4.0K Oct 21 2021 scripts
4 drwxr-xr-x 16 root root 4.0K Oct 21 2021 public
36 -rw-r--r-- 1 root root 33.7K Oct 21 2021 LICENSE
4 -rw-r--r-- 1 root root 108 Oct 21 2021 NOTICE.md
4 -rw-r--r-- 1 root root 2.8K Oct 21 2021 README.md
Since root owns the grafana folder inside the container, I’ve tried setting the docker run --user flag to root:root, 0:0, and 472:0:, and none of these combinations seem to work.
The default UID and GID inside the container, when the --user flag is not set in docker run, is:
$ echo "`id -u`:`id -g`"
472:0
What am I doing wrong?
edit: I am going to make a custom Dockerfile just so I can chown the /usr/share/grafana folder while building the image. I have a good feeling this will work, but it just doesn’t seem like this should be necessary in order to get support for provisioning Grafana when deployed via Docker.
