Grafana-oss:9.0.2 failed to start
    using Grafana-oss:9.0.2
    Ubuntu Version="18.04.6 LTS (Bionic Beaver)
    To run docker container successfully
    pulled docker image grafana/grafana-oss:9.0.1 from docker hub to local, updated the docker compose file and run the container
  • What happened?
    Its showing an error as:
    Grafana server is running with elevated privileges. This is not recommended
    logger=settings t=2022-06-30T00:41:23.060835725Z level=info msg=ā€œStarting Grafanaā€ version=9.0.2 commit=0641b5d0cd branch=HEAD compiled=2022-06-28T11:24:40Z
    logger=settings t=2022-06-30T00:41:23.063593898Z level=info msg=ā€œConfig loaded fromā€ file=/usr/share/grafana/conf/defaults.ini
    logger=settings t=2022-06-30T00:41:23.063613541Z level=info msg=ā€œConfig loaded fromā€ file=/etc/grafana/grafana.ini
    logger=settings t=2022-06-30T00:41:23.063627805Z level=info msg=ā€œConfig overridden from command lineā€ arg=ā€œdefault.paths.data=/var/lib/grafanaā€
    logger=settings t=2022-06-30T00:41:23.06363651Z level=info msg=ā€œConfig overridden from command lineā€ arg=ā€œdefault.paths.logs=/var/log/grafanaā€
    logger=settings t=2022-06-30T00:41:23.063644295Z level=info msg=ā€œConfig overridden from command lineā€ arg=ā€œdefault.paths.plugins=/var/lib/grafana/pluginsā€
    logger=settings t=2022-06-30T00:41:23.063651885Z level=info msg=ā€œConfig overridden from command lineā€ arg=ā€œdefault.paths.provisioning=/etc/grafana/provisioningā€
    logger=settings t=2022-06-30T00:41:23.063660507Z level=info msg=ā€œConfig overridden from command lineā€ arg=ā€œdefault.log.mode=consoleā€
    logger=settings t=2022-06-30T00:41:23.063672142Z level=info msg=ā€œConfig overridden from Environment variableā€ var=ā€œGF_PATHS_DATA=/var/lib/grafanaā€
    logger=settings t=2022-06-30T00:41:23.063696731Z level=info msg=ā€œConfig overridden from Environment variableā€ var=ā€œGF_PATHS_LOGS=/var/log/grafanaā€
    logger=settings t=2022-06-30T00:41:23.063708829Z level=info msg=ā€œConfig overridden from Environment variableā€ var=ā€œGF_PATHS_PLUGINS=/var/lib/grafana/pluginsā€
    logger=settings t=2022-06-30T00:41:23.06371857Z level=info msg=ā€œConfig overridden from Environment variableā€ var=ā€œGF_PATHS_PROVISIONING=/etc/grafana/provisioningā€
    logger=settings t=2022-06-30T00:41:23.063726019Z level=info msg=ā€œConfig overridden from Environment variableā€ var=ā€œGF_SERVER_ROOT_URL=https://grafana.sdx.com:3000ā€
    logger=settings t=2022-06-30T00:41:23.063736325Z level=info msg=ā€œPath Homeā€ path=/usr/share/grafana
    logger=settings t=2022-06-30T00:41:23.063744343Z level=info msg=ā€œPath Dataā€ path=/var/lib/grafana
    logger=settings t=2022-06-30T00:41:23.063751519Z level=info msg=ā€œPath Logsā€ path=/var/log/grafana
    logger=settings t=2022-06-30T00:41:23.06376486Z level=info msg=ā€œPath Pluginsā€ path=/var/lib/grafana/plugins
    logger=settings t=2022-06-30T00:41:23.063773012Z level=info msg=ā€œPath Provisioningā€ path=/etc/grafana/provisioning
    logger=settings t=2022-06-30T00:41:23.063780738Z level=info msg=ā€œApp mode productionā€
    Failed to start grafana. error: section ā€œtracing.opentelemetry.otlpā€ does not exist
    To run the container successfully
No.
are you still blocked on this?
Upon updating the existing file /etc/grafana/grafana.ini with the otlp block with reference to the latest grafana.ini file made for grafana version 9.0.2, the issue got resolved
iā€™m also stuck starting grafana 9.0.2.
what is the ā€œotipā€ block ??
Eric.
For me, adding (the otip block):
[tracing.opentelemetry.otlp]
and
[tracing.opentelemetry]
to the end of /usr/share/grafana/conf/defaults.ini made grafana start again,
you may have to add it to /etc/grafana/grafana.ini instead, depending on where grafana reads its config file from.
@padlefot thanks a ton. It worked. adding the telemetry block will resolve the issue. As an alternate, we can replace the complete defaults.ini content with the GitHub repo and fine-tune the values as per the required environment.
