After attempting to upgrade a working version of Grafana (8.0.4.0) to version 9.0.5.0, the Grafana service does not start.
9.0.5.0 Windows -
Upgrade Grafana / Start Grafana post upgrade -
Downlaoded the Windows 9.0.5.0 installer and ran it. -
What happened?
Installer finished, restarted the Host, Grafana fails to start. -
Grafana starts post upgrade. -
Grafana exited with return code 1
grafana-server.exe
e[32mINFO e[0m[07-27|20:50:57] Starting Grafana e[32mloggere[0m=settings e[32mversione[0m=9.0.5 e[32mcommite[0m=1b595e434a e[32mbranche[0m=HEAD e[32mcompilede[0m=2022-07-26T09:35:28Z
e[32mINFO e[0m[07-27|20:50:57] Config loaded from e[32mloggere[0m=settings e[32mfilee[0m=“C:\Program Files\GrafanaLabs\grafana/conf/defaults.ini”
e[32mINFO e[0m[07-27|20:50:57] Path Home e[32mloggere[0m=settings e[32mpathe[0m=“C:\Program Files\GrafanaLabs\grafana”
e[32mINFO e[0m[07-27|20:50:57] Path Data e[32mloggere[0m=settings e[32mpathe[0m=“C:\Program Files\GrafanaLabs\grafana\data”
e[32mINFO e[0m[07-27|20:50:57] Path Logs e[32mloggere[0m=settings e[32mpathe[0m=“C:\Program Files\GrafanaLabs\grafana\data\log”
e[32mINFO e[0m[07-27|20:50:57] Path Plugins e[32mloggere[0m=settings e[32mpathe[0m=“C:\Program Files\GrafanaLabs\grafana\data\plugins”
e[32mINFO e[0m[07-27|20:50:57] Path Provisioning e[32mloggere[0m=settings e[32mpathe[0m=“C:\Program Files\GrafanaLabs\grafana\conf\provisioning”
e[32mINFO e[0m[07-27|20:50:57] App mode production e[32mloggere[0m=settings
Failed to start grafana. error: section “tracing.opentelemetry.jaeger” does not exist
- Did you follow any online instructions? If so, what is the URL?
