Tried upgrading from version 7 to the latest version 8.0.6 and the service will not start.
Windows says:
Grafana 8.06 windows installer
Windows Server 2016 x64 -
Upgraded to the latest version and the service is not starting -
What happened?
Backup up files, ran the installer, new service didn’t start -
t=2021-07-29T10:14:06-0700 lvl=info msg="Starting Grafana" logger=server version=8.0.6 commit=68fe9e3431 branch=HEAD compiled=2021-07-15T00:49:19-0700
t=2021-07-29T10:14:06-0700 lvl=info msg="Config loaded from" logger=settings file="C:\\Program Files\\GrafanaLabs\\grafana/conf/defaults.ini"
t=2021-07-29T10:14:06-0700 lvl=info msg="Config loaded from" logger=settings file="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\custom.ini"
t=2021-07-29T10:14:06-0700 lvl=info msg="Path Home" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana"
t=2021-07-29T10:14:06-0700 lvl=info msg="Path Data" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data"
t=2021-07-29T10:14:06-0700 lvl=info msg="Path Logs" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\log"
t=2021-07-29T10:14:06-0700 lvl=info msg="Path Plugins" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\plugins"
t=2021-07-29T10:14:06-0700 lvl=info msg="Path Provisioning" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\provisioning"
t=2021-07-29T10:14:06-0700 lvl=info msg="App mode production" logger=settings
t=2021-07-29T10:14:06-0700 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
t=2021-07-29T10:14:06-0700 lvl=warn msg="SQLite database file has broader permissions than it should" logger=sqlstore path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\grafana.db" mode=-rw-rw-rw- expected=-rw-r-----
t=2021-07-29T10:14:06-0700 lvl=info msg="Starting DB migrations" logger=migrator
t=2021-07-29T10:14:06-0700 lvl=info msg="migrations completed" logger=migrator performed=0 skipped=330 duration=2.0065ms
t=2021-07-29T10:14:06-0700 lvl=info msg="Starting plugin search" logger=plugins
t=2021-07-29T10:14:06-0700 lvl=warn msg="The following files were not included in the signature" logger=plugins plugin=input files=[LICENSE]
t=2021-07-29T10:18:23-0700 lvl=info msg="Starting Grafana" logger=server version=8.0.6 commit=68fe9e3431 branch=HEAD compiled=2021-07-15T00:49:19-0700
t=2021-07-29T10:18:23-0700 lvl=info msg="Config loaded from" logger=settings file="C:\\Program Files\\GrafanaLabs\\grafana/conf/defaults.ini"
t=2021-07-29T10:18:23-0700 lvl=info msg="Config loaded from" logger=settings file="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\custom.ini"
t=2021-07-29T10:18:23-0700 lvl=info msg="Path Home" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana"
t=2021-07-29T10:18:23-0700 lvl=info msg="Path Data" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data"
t=2021-07-29T10:18:23-0700 lvl=info msg="Path Logs" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\log"
t=2021-07-29T10:18:23-0700 lvl=info msg="Path Plugins" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\plugins"
t=2021-07-29T10:18:23-0700 lvl=info msg="Path Provisioning" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\provisioning"
t=2021-07-29T10:18:23-0700 lvl=info msg="App mode production" logger=settings
t=2021-07-29T10:18:23-0700 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
t=2021-07-29T10:18:23-0700 lvl=warn msg="SQLite database file has broader permissions than it should" logger=sqlstore path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\grafana.db" mode=-rw-rw-rw- expected=-rw-r-----
t=2021-07-29T10:18:23-0700 lvl=info msg="Starting DB migrations" logger=migrator
t=2021-07-29T10:18:23-0700 lvl=info msg="migrations completed" logger=migrator performed=0 skipped=330 duration=4.0059ms
t=2021-07-29T10:18:23-0700 lvl=info msg="Starting plugin search" logger=plugins
t=2021-07-29T10:18:23-0700 lvl=warn msg="The following files were not included in the signature" logger=plugins plugin=input files=[LICENSE]
