Grafana server not start (after 8.2.0 upgrade)
Hi there, after the upgrade to the 8.2.0 version , I got this message:
● grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; disabled; ven
Active: failed (Result: start-limit-hit) since ven 2021-10-08 11:04:51 CEST;
Docs: http://docs.grafana.org
Process: 21812 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidf
Main PID: 21812 (code=killed, signal=SYS)
ott 08 11:04:51 server systemd[1]: grafana-server.service: Main process exited,
ott 08 11:04:51 server systemd[1]: grafana-server.service: Unit entered failed s
ott 08 11:04:51 server systemd[1]: grafana-server.service: Failed with result 's
ott 08 11:04:51 server systemd[1]: grafana-server.service: Service hold-off time
ott 08 11:04:51 server systemd[1]: Stopped Grafana instance.
ott 08 11:04:51 server systemd[1]: grafana-server.service: Start request repeate
ott 08 11:04:51 server systemd[1]: Failed to start Grafana instance.
lines 1-16/16 (END)…skipping…
[ Linux server 4.4.0-210-generic #242-Ubuntu ]
[Description: Ubuntu 16.04.7 LTS xenial]
How could fix it? Thank you very much for your support
I am having the same problem. Service will not start following the 8.2.0 upgrade yesterday.
Same problem on two Ubuntu 18.04.6 LTS machines.
Couldn’t find any relevant log entrys.
I have the same problem on Ubuntu 18.04 .
It seams like it gets killed, when I try to start it with systemd.
audit: type=1326 audit(1633704633.616:24): auid=4294967295 uid=121 gid=132 ses=4294967295 pid=30500 comm=“grafana-server” exe="/usr/sbin/grafana-server" sig=31 arch=c000003e syscall=12 compat=0 ip=0x7f7c414730a9 code=0x0
If I start it manually it will start and work…
To fix this just comment some parameters in the systemd-file.
I think, this is because of the old systemd in the 18.04
cat /usr/lib/systemd/system/grafana-server.service  | grep "#"
#ProcSubset=pid
#ProtectClock=true
#ProtectHostname=true
#ProtectKernelLogs=true
#ProtectProc=invisible
#SystemCallFilter=@system-service
Thanks. Now I’m a step further.
The new error is now that of the image-renderer, from the other topic Image-renderer preventing grafana-server 8.2.0 to start
Thanks, this helped me get up and running again after an apt upgrade.
$ lsb_release -a
Description:    Ubuntu 18.04.6 LTS
$ uname -a
Linux 4.15.0-159-generic #167-Ubuntu SMP Tue Sep 21 08:55:05 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
I have the same problem on Debian 9.13. But my systemd-file has no such parameter.
Thanks a lot. This fix worked for me on my raspberry pi.
Hallo,
I installed grafana fo the first time an I didn´t start with the granafa-server startup.
sudo /bin/systemctl start grafana-server
Manual it works: sudo /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --homepath=/usr/share/grafana
Please explain me how you fix the startup problem on raspberry pi.
Best regards
Kasper
I can confirm rolling back to 8.1.6 on my Ubuntu 20.04 instance fixed things.
It looks like Systemd: Upgrading from 8.0.6 to 8.2.0 broke grafana · Issue #40162 · grafana/grafana · GitHub is tracking this.
for me the solution from @altuhovd did work. Just open the file /usr/lib/systemd/system/grafana-server.service in an editor and comment all lines with the hash “#” sign as shown in Dimitriy’s post above.
Meanwhile saw the next post from @deviantintegral and could figure out that only the line
has to be commented and grafana service starts without issues.
thank the only think it works on my pi was to edit the /usr/lib/systemd/system/grafana-server.service and change the code to:
I hope I have no other problems
Thank you for your fast answer.
[Unit]
Description=Grafana instance
Documentation=http://docs.grafana.org
Wants=network-online.target
After=network-online.target
After=postgresql.service mariadb.service mysql.service
[Service]
EnvironmentFile=/etc/default/grafana-server
User=grafana
Group=grafana
Type=simple
Restart=on-failure
WorkingDirectory=/usr/share/grafana
RuntimeDirectory=grafana
RuntimeDirectoryMode=0750
ExecStart=/usr/sbin/grafana-server                                                  \
                            --config=${CONF_FILE}                                   \
                            --pidfile=${PID_FILE_DIR}/grafana-server.pid            \
                            --packaging=deb                                         \
                            cfg:default.paths.logs=${LOG_DIR}                       \
                            cfg:default.paths.data=${DATA_DIR}                      \
                            cfg:default.paths.plugins=${PLUGINS_DIR}                \
                            cfg:default.paths.provisioning=${PROVISIONING_CFG_DIR}
LimitNOFILE=10000
TimeoutStopSec=20
UMask=0027
[Install]
WantedBy=multi-user.target
Hello @altuhovd , thank you very much for your help. This solution worked for me
What I actually did to make it running normally, I opened grafana-server.service
sudo nano /usr/lib/systemd/system/grafana-server.service
and I commented the #SystemCallArchitectures=native
Then I started again grafana and it works
