Grafana failed to start (10.0.1)
    Grafana 10.0.1 Unbuntu 22.04.2
Installed with commands on grafana. com/docs/grafana/latest/setup-grafana/installation/debian/ (stable version)
grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server. service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code)
systemd[1]: grafana-server. service: Start request repeated too quickly.
systemd[1]: grafana-server. service: Failed with result ‘exit-code’.
systemd[1]: Failed to start Grafana instance.
these two solutions included reinstalling grafana and rolling back to a previous version. Neither of these solutions worked
Hi @irischen999,
Thanks for opening this post.
Could you please provide us with the backend logs (the default location in Linux is /var/log/grafana/grafana.log) so that we can have more information about the error message?
I was actually able to fix the problem by deleting files and directories that had the word ‘grafana’ in them manually. sudo apt-get remove --auto-remove grafana and sudo apt-get purge grafana did not remove all of them. After doing that and following the installation as normal, it was working again.
however, I don’t know how to make this thread as resolved
Glad to hear that you found the solution.
That I just did now :smiley:
