Grafana-server.service: Start request repeated too quickly
    grafana-enterprise_9.0.6_amd64.deb
    ubuntu 20.04LTS
    start garafana server
  • install grafana from https://dl.grafana.com/enterprise/release/grafana-enterprise_9.0.6_amd64.deb
  • sudo dpkg -i grafana-enterprise_9.0.6_amd64.deb
  • sudo /bin/systemctl start grafana-server
  • What happened?
    when checking the grafana server status from systemctl
    got this,
systemctl status grafana-server
● grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2022-08-04 02:30:39 +0530; 679ms ago
Docs: http://docs.grafana.org
Process: 48912 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:>
Main PID: 48912 (code=exited, status=1/FAILURE)
Aug 04 02:30:39 lap-L systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Aug 04 02:30:39 lap-L systemd[1]: Stopped Grafana instance.
Aug 04 02:30:39 lap-L systemd[1]: grafana-server.service: Start request repeated too quickly.
Aug 04 02:30:39 lap-L systemd[1]: grafana-server.service: Failed with result ‘exit-code’.
Aug 04 02:30:39 lap-L systemd[1]: Failed to start Grafana instance.
    grafana server start and show running status on systemctl
    don’t know
Aug 04 02:30:39 lap-L systemd[1]: grafana-server.service: Failed with result 'exit-code'.
    Grafana official web site
@yahampath this looks similar to an issue we saw and fixed in 8.5.1 - grafana-server doesn't start after recent update to 8.5.0 on openhabian · Issue #48130 · grafana/grafana · GitHub
Another user has reported seeing it recently, so I’ve asked what release they’re on. I’d suggest opening a new issue for this in our grafana repo
Iam also facing same error but different situation. The situation is iam trying to edit default configuration and trying to bring up the service ,while trying to restart the service iam facing the error.
I’m seeing the same error starting Alloy
