Grafana-server.service failed to start
I have problems to start grafana-server.service.
Up until 02/20/22 everything ran without problems.
Now the service doesn’t start anymore.
Information:
Ubuntu 20.04 LTS
Zabbix Server 5.4
Grafana Server 8.3.4
● grafana-server.service - Grafana instance
     Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
     Active: failed (Result: core-dump) since Tue 2022-01-25 11:09:08 UTC; 3s ago
       Docs: http://docs.grafana.org
    Process: 6852 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs=${LOG_DIR} cfg:default.paths.data=${DATA_DIR} cfg:default.paths.plugins=${P>
   Main PID: 6852 (code=dumped, signal=SEGV)
Jan 25 11:09:08 zabgra systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Jan 25 11:09:08 zabgra systemd[1]: Stopped Grafana instance.
Jan 25 11:09:08 zabgra systemd[1]: grafana-server.service: Start request repeated too quickly.
Jan 25 11:09:08 zabgra systemd[1]: grafana-server.service: Failed with result 'core-dump'.
Jan 25 11:09:08 zabgra systemd[1]: Failed to start Grafana instance.
Does somebody has any idea… Thanks…
I have fix the problem. Reinstall “grafana” package.
I don’t know why it was corrupt.
apt-get --reinstall install grafana
Thanks…
Active: failed (Result: exit-code) since Mon 2022-10-31 12:01:45 IST; 915ms ago
Process: 72134 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.>
Main PID: 72134 (code=exited, status=1/FAILURE)
Oct 31 12:01:45 kcs-OptiPlex-3020 systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Oct 31 12:01:45 kcs-OptiPlex-3020 systemd[1]: Stopped Grafana instance.
Oct 31 12:01:45 kcs-OptiPlex-3020 systemd[1]: grafana-server.service: Start request repeated too quickly.
Oct 31 12:01:45 kcs-OptiPlex-3020 systemd[1]: grafana-server.service: Failed with result ‘exit-code’.
Oct 31 12:01:45 kcs-OptiPlex-3020 systemd[1]: Failed to start Grafana instance.
any idea about this
