How to enable Query Caching In Grafana
Hi ,
From my Grafana Panel , I am making a REST call to a custom Data Source ( A REST Service ) which sends the response back to Grafana with the required data.
I am using Grafana 10.3.3.
How to enable query caching for this particular Data source ?
I did not see any option.
Thanks,
Nilanjan
Enable that in your datasource configuration (if datasource supports that). For example:
Doc:
Keep in mind:
Available in Grafana Enterprise and Grafana Cloud.
For the Datasource that I am using …do not see any Cache configurations.
Any way to enable it .?
It is top secret which data source type you are using when you don’t mention it? Be specific as much possible; otherwise, you will get a generic answer: I don’t know - check the documentation for that datasource, pls.
