Grafana v10.0.0 (81d85ce802) -
I am trying to get the caching work with Grafana data sources so that the queries are not fired to the backend data source on every refresh of the page.
I have enabled caching on the data source as shown in the image below
What happened?
When I refresh the dashboard without changing dashboard variables, the queries are fired always to the backend Datasource.
I expect Grafana to not fire the backend queries and instead retrieve the results from the cache -
I have 3 panels in the dashboard and everytime, I see all the 3 queries fired.
