Hello, I am new to Grafana and InfluxDB in general so forgive me if this question sounds “noobish”.
I have created a database named “TA_Dis” and a measurement named “onofflampu” whose content look like this:
I want to display k1, k2, k3, k4, and k5 to the graph in Grafana, however the data just won’t show up even though I have set the correct time window. To test, I just want to display the column k1 first. From the query inspector, my query looks like this:
"SELECT "k1" FROM "onofflampu" WHERE time >= 1548832576000ms and time <= 1548843376074ms"
This is the query editor:
The result is just a blank graph with the text “No data points”
I have searched other forums but unfortunately I was unable to find the solution.
Any kind of help is appreciated! Thank you in advance!
I am running both Grafana and InfluxDB on Windows 7 (SP1)
The Grafana version I’m using is v. 5.4.3, and the InfluxDB version is v. 1.7.3
