How to display nested query on Grafana
I want to display a table panel that can show nested query
I want to display
Screen Shot 2021-06-10 at 6.33.15 AM
will appreciate your help!!
Hi @rnayar,
If I understand correctly, you want to nest on table panel inside of another table panel. If that’s correct, then unfortunately it is not possible at this time. I think you are touching on an idea of atomic panels, which is of interest to many.
If you wanted to pursue this, then I would suggest adding it to GitHub discussion in the Grafana repo. Starting July 20, 2021, we will be moving all feature requests to that channel :+1:
