Grafana v8.4.0-Beta
datasource: Prometheus
- What are you trying to achieve?
I am trying to achieve a display of two or more queries in one table in a panel. I would like the query to display an overview of every node. something like in the picture below:
- How are you trying to achieve it?
I am just new to Grafana, and what I tried to do is to select Table in visualization and add 3 queries separately. I tried to use transform but I did not get around it. see the image below:
What happened?
What happened is, the dashboard does not display the table with the column as I expected. I tried to add an override in the setting but I can not see the column to edit.
I know the query will filter only when the alert of the instance is in a firing state, but how to will I filter when in a normal state? -
I expect to have something similar to this below
Thanks in Advance
