v9.2.5 on Ubuntu 20.04 -
Display data in a table panel on a dashboard -
With a flux query (InfluxDB 2.5) -
What happened?
In Explore the query works fine and displays everything in one table.
In the table panel the table is split up in many small tables but I am using the same query.
I did try to merge the tables with transformations, but it didn’t work. -
Show data from Influx database in one table -
Flux Query:
from(bucket: "my-bucket") |> range(start: v.timeRangeStart, stop: v.timeRangeStop)
|> filter(fn: (r) => r["_measurement"] == "Eventer" or r["_measurement"] == "Farberkennung" or r["_measurement"] == "Personenfilter" or r["_measurement"] == "importer")
|> filter(fn: (r) => r["_field"] == "nachricht" or r["_field"] == "motornummer" or r["_field"] == "level")
|> filter(fn: (r) => r["level"] == "Fehler")
No errors -
I found nothing related to this topic.
My main question is, if there is a difference between table panel and explore and how can I configure the table panel to look like the view from explore.
Thank you in advance.
